external ph8a filter cause foaming? - Ford Truck Enthusiasts Forums
Old 02-26-2002, 11:43 AM
daves302gt daves302gt is offline
daves302gt is starting off with a positive reputation.
Can you guys think of a reason that an external ph8a filter i attached in line with the tranny would cause the fluid to foam?? i'm not positve that that install caused it, becuase i changed a bunch of things at the same time. has anyone ever done this mod? too many variables for me to sort out. Thanks
dave
Old 02-26-2002, 11:21 PM
destiny88 destiny88 is offline
destiny88 is starting off with a positive reputation.
The main thing to cause foaming is overfilling. Make sure it is hot and level when you check the level
Old 02-27-2002, 04:21 PM
well i got some info from a tranny shop today that said that the c4 is particularly sensitive to valve body leaks if it isn't bolted down exacly right. so maybe when i took it out last time, i bolted it unevenly. when it has leaks, they said it will foam. i will go into the tranny this week and re set it. i'll keep you posted on my results! thanks
dave
Old 03-15-2002, 08:59 AM
well, i talked to an autoparts store and they pointed out that a ph8a is meant for a high pressure system, like 20 psi and above, but a tranny only puts out about 7psi. also, the b&m kit said that if i was getting foaming the cooler or cooler line was probalby clogged. I'm guessing that the oil filter was "clogging" it. i removed it but i still have foaming, even after re-checking the shift kit install. I'm gonna try bypassing the stock cooler with an aftermarket cooler, just in case the radiator one is clogged. i'll keep you updated.
dave
Old 03-15-2002, 03:42 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
Old 04-20-2013, 09:11 PM
95250mac 95250mac is offline
95250mac is starting off with a positive reputation.
The Magnefine trans and power steering filter is a great product and is made for that application.
Fram oil filter for 1994 F150 6 cyl? Crenra 1987 - 1996 F150 & Larger F-Series Trucks 30 03-16-2008 07:50 AM
Compact Oil Filter rswhitmore Oil & Lubrication 6 08-04-2007 03:04 AM
PH8 vs. PH8A oil filter Beanscoot Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 06-10-2007 02:09 AM
The FL-1A & Some Equivalents Ranked by Element Area: TABLE UPDATED BY Big O Dave Big O Dave Oil & Lubrication 28 09-13-2005 03:19 PM
04 5.4L 24V Fram oil filer help stretch five oh 2004 - 2008 F150 4 06-05-2005 06:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
