Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-10-2009, 04:05 PM
wolfrum wolfrum is offline
wolfrum is starting off with a positive reputation.
bronco 302 to 429
how much work in involved in swapin a 302 fi to a 429 carb? motor mounts? tranny mounts drive shafts? fuel lines and all the other stuff? help its my first swap...
thanks
  #2 (permalink)
Old 06-11-2009, 12:00 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a good reputation on FTE. Kemicalburns has a good reputation on FTE.
depends on what year bronco your working on.
basicly everything will need changed. if your 302 is currently efi you would have an easier time swapping in an efi 460. but regardless this will require a big block tranny.
__________________
94 XLT 5.8/E4OD/Warn HS9500I
6"ProComp Stage II 35x12.5x15 BFG MT's
4.88 gears/Aussie Front/rear open
JBA shorty, Custom Y pipe,3" exhaust
http://www.supermotors.org/registry/...il.php?id=4158
  #3 (permalink)
Old 06-11-2009, 02:45 PM
its a 90 bronco
  #4 (permalink)
Old 06-11-2009, 02:52 PM
ok well being a 90 bronco you dont have to worry about abs and all the electrical integration like 92+ broncos.
are you planning to do the work yourself or having a shop do the work?
do you have another tranny lined up? you can keep the Tcase thats in the bronco. you might consider going to a 3/4 or 1 ton rear end and then doing an 8 lug conversion up front so your running same wheels. the 8.8 will be marginal with that much power.
what do you use the bronco for?
__________________
  #5 (permalink)
Old 06-12-2009, 04:08 PM
i have a tranny out of a 78 F250 HB
its gonna be a mud and trail truck
  #6 (permalink)
Old 06-12-2009, 04:10 PM
and i want to do it all myself
  #7 (permalink)
Old 06-12-2009, 04:47 PM
so the tranny out of the 78 is a C6 correct. sounds like fun. the swap has been done a lot by a lot of people. search the forums i am sure you will get specifics on this.
__________________
  #8 (permalink)
Old 06-22-2009, 01:46 PM
cadunkle's Avatar
cadunkle cadunkle is offline
cadunkle is starting off with a positive reputation.
This should be a fairly easy swap. I recently swapped my '86 F-250 from 351w to 460. Get the L&L motor mounts and oil filter relocation kit if the filter won't clear your Bronco crossmember. Everything else should line up and be real close. Crossmember adn driveshafts will probably be the same, if not that's easy enough to fix. You'll need to ditch the in-tank fuel pump. Remove sender and cut the pump off, extend pickup to bottom of tank. Either that or run an early style carb fuel tank/pickup. Pretty much a bolt in swap.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
