Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Sign in using an external account
Register Forgot Password?
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Closed Thread
  #1 (permalink)
Old 06-10-2009, 08:27 AM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
2005 Ford F-150
FTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to all
Idunthave1yet
'04-'08 F-150 Tech Folder (Repairs, Tips, Tricks, and Helpful info)
ultimate-torque-spec-list
For all you "Edge heads!"
Edge Owners Tuning Thread:
http://www.ford-trucks.com/forums/47...ng-thread.html
Need Help removing the Rear seat and finding your "lost" keyless entry code?
Try Here: Easy Rear Seat Removal For 2004 - 2008 F-150 .: Articles
IWE and solenoid related issues (4WD):
Pics of the solenoid here: http://www.ford-trucks.com/forums/80...-solenoid.html (Courtesy of user: Mattd17)
..And Everything you wanted to know about the IWE System: http://www.ford-trucks.com/forums/83...then-some.html (Courtesy of user: xjcamaro89)
Need help Diagnosing the Brake switch or shifter interlock? You can start here at this thread:
http://www.ford-trucks.com/forums/55...r-stuck-2.html
MISC...
A decent info thread on a Pwr window and keyless entry with a tach and Vacuum gauge install (Courtesy of Chris Adams):
http://www.ford-trucks.com/forums/30...dow-power.html
(more threads of these topics to follow)
Needing to add a Sirius or I-Pod jack.... Click Here
PATS Thread - Program Your Own Keys & Other Useful PATS Info (Courtesy of Tylus)
further updates will continue...
__________________
-Rich; SC-DPS Reserve Trooper
'05 ReCab XL Pw,pwdlk, cruise & more w/139K
Chapters / 2004-2010 F150 / 2011 F100 Moderator
  #2 (permalink)
Old 02-19-2012, 12:00 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
2002 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
CelticDevilDog's MAF cleaning thread.
Quote:
Originally Posted by CelticDevilDog View Post
I know that this is an incredibly simple process but sometimes I find things easier with pictures. I couldn't find anything like that on this site, there were lots of references to cleaning the MAF and I wanted to clean mine. I figured I would create a simple tutorial and give back to the community that has helped me so much.
Here are the tools you will need:
1) CRC Mass Air Flow Sensor cleaner. Do NOT use break cleaner or anything else that is not designed for electronics. About $8 at a local parts store.
2) Flat head screw driver
3) T-20 Torx bit
The MAF is located on the driver's side of the Air filter housing
Use the screwdriver to pull the red tab out. It pulls out like a drawer and not up or down like many tabs.
Gently pull the connector off the MAF. If this has never been done on your truck before you may need to use the screw driver on the red tab to give you a little more help. It should slide right off.
Next, use the T-20 torx bit to remove the two screws holding the MAF to the air filter housing. There is one on the top left of the sensor (shown below) and one on the bottom right of the sensor.
Gently pull the sensor out. Be sure to not get any dirt into the air filter housing when you remove the MAF.
Spray the MAF and let it dry for about 10-15 seconds. Do NOT touch the wires in the MAF with anything other than the CRC cleaner.
To put it back follow the procedure in reverse order.
Cleaning the MAF is a good idea every time you change/oil your air filter as it can get dirty from all the dust and oil that may come through your air filter.
If you have any questions or there is more information I can add to this tutorial let me know.
http://www.ford-trucks.com/forums/11...l#post11455395
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
2002 PSD F250 SC 4x2: 38R, AC's, Terminated, MBRP, AFE, JWVB, HPX & FRx, OBA, Live Tuned
2000 PSD Excursion 4x4: 38R, JW 4R100, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
Closed Thread
Tags
04, 150, 2005, 2008, 4wd, f150, ford, gauge, install, issues, iwe, related, solenoid, tips, tricks, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
