Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Computer Chips and Tuners SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-10-2009, 08:14 AM
sumbuddyloanmea.10 sumbuddyloanmea.10 is offline
sumbuddyloanmea.10 is starting off with a positive reputation.
Want to chip my PS . . .????Which 1?
I've done the Googleing, searched this site up & down, now I know enough to be dangerous . . . But my situation is not answered.
Mine is the '01 F350 PS with auto trans. The only mods are the huge air filter I put on and the valve cover breather by-pass thingy. I'm wanting to chip to add towing power and improve mpg's. I'm not interested at sitting at the light and lighting up all 4's. Some guys get off on that. My needs are more practical.
I tow a 5er that can weigh 12K lbs. I get 10 or less mpg when I do. I live at high altitude (over 6000 feet) and drive at highway speeds often times over mountain pass and camp and hunt at about 10K feet or so.
Which chip would suit be best (or a site that will compare and explain),Superchip, / DP / TS / Edge / Banks / Tony Wildman / Boss / Bully Dog . . ..
Are there more???!!!
I would like the feature of changeing settings on the fly and easy to install and set up.
  #2 (permalink)
Old 06-10-2009, 08:07 PM
tex25025's Avatar
tex25025 tex25025 is online now
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
DP I think is the most preferred with the 7.3 guys out there. Second I would think would be Tony Wildman tuning.
As to shifting on the Fly, I don't know how well the 7.3 handles with it, but speaking from a 6.0 perspective, shifting on the fly does more harm then good and when you get over the novelty of it all, "you" typically leave it on one setting as it is.
I would go on over to the 7.3 forum and see what those guys say about shift on the fly for that engine, I can only tell you it's not good for the 6.0 or the torqshift.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
Suncoast Heavy Duty Torqshift Rebuild
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #3 (permalink)
Old 06-17-2009, 08:07 PM
DSTRBD's Avatar
DSTRBD DSTRBD is offline
PREMIUM SPONSOR
DSTRBD is starting off with a positive reputation.
From what you described, I think DP Tuner is going to be your best bet. Jody has a ton of tune options available and they are adjustable on the fly.
You may also want to consider an exhaust system to help keep the EGTs down once you chip it.
__________________
Performance Truck Products
888-516-4644
Got Questions? Chat LIVE on Our Site
  #4 (permalink)
Old 06-24-2009, 08:48 AM
agg_bagg agg_bagg is offline
agg_bagg is gaining momentum as a positive member of FTE.
I have a 7.3L and a DP is the way to go.
__________________
Jeron
Early 99 F250 SD PSD Super Cab, 210,000 miles, 4" lift 35" tires, Hutch & Harpoon, CCV, 6637, TransGo Tugger with rebuild, DiPricol Gauges EGT/Boost/Trans Temp, Door Lock Foil Fix
  #5 (permalink)
Old 06-24-2009, 10:08 AM
Pocket's Avatar
Pocket Pocket is online now
Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold
I've been running DP-Tuner for 4 years now. Jody is a good guy. I just saw him this weekend for live tuning in Denver.
Others that also do a good job are Total Diesel Performance, Power Hungry Performance, and Diesel Innovations.
The big name brands like Superchips, Banks, Bully Dog, Hypertech, and others aren't really the most preferred for 7.3L's.
[quote=As to shifting on the Fly, I don't know how well the 7.3 handles with it, but speaking from a 6.0 perspective, shifting on the fly does more harm then good and when you get over the novelty of it all, "you" typically leave it on one setting as it is.
I would go on over to the 7.3 forum and see what those guys say about shift on the fly for that engine, I can only tell you it's not good for the 6.0 or the torqshift. [/quote]
Tex, switch on the fly is perfectly fine for our trucks, and it's usually the most preferred for 7.3L owners.
__________________
Curtis
2002 F-250 PSD
Best time: 15.3 @ 86.8 MPH at Bandimere - 9/10/08
Truck Pics
Quote:
The phrase "It'll make a turd" is not considered a compliment when referring to the quality of dinner.
  #6 (permalink)
Old 06-24-2009, 11:05 AM
tex25025's Avatar
Quote:
Yea, all y'alls trucks seem to be able to get away with more "stuff" then us 6.0 guys can.
__________________
Fluidampner
Headstuds
FASS 150/180
  #7 (permalink)
Old 06-24-2009, 12:15 PM
Very helpful stuff guys . . . but after going to the DP site, I'm not sure which product would be best for my needs.
F6, X3, or F5?
The F6 looks like the all to end all . . . but @ $400.00!?
  #8 (permalink)
Old 06-24-2009, 12:16 PM
Pocket's Avatar
Quote:
But you guys make more power....
Now that a 6.0L has hit 1000 hp, you have some bragging rights. At least it's still a Powerstroke
__________________
Curtis
2002 F-250 PSD
Truck Pics
  #9 (permalink)
Old 06-24-2009, 12:21 PM
Pocket's Avatar
Quote:
F6, X3, or F5?
F5 and F6 function about the same. The F6 allows you to receive updated tunes via email and load them directly from your laptop. DP-Tuner is phasing out the F5, so they are priced much cheaper. If you want updated tunes to the F5, you have to ship your chip back to DP-Tuner. Turnaround is typically a few days.
The X3 is an SCT programmer and can hold up to 3 custom tunes from DP-Tuner (or anyone else). Since it's a programmer, it doesn't switch tunes on the fly. You have to have the engine off, and load tunes to the PCM to switch from one setting to the next. Takes about 2 minutes to switch between tunes.
__________________
Curtis
2002 F-250 PSD
Truck Pics
  #10 (permalink)
Old 06-26-2009, 09:30 AM
DP-Tuner's Avatar
DP-Tuner DP-Tuner is offline
PREMIUM SPONSOR
DP-Tuner has a great reputation on FTE. DP-Tuner has a great reputation on FTE. DP-Tuner has a great reputation on FTE. DP-Tuner has a great reputation on FTE. DP-Tuner has a great reputation on FTE.
We are not discontinuing the F5. It will always be available.
The F6 has much more technology behind it. It has been designed with a burner function right on the chip to be able to download tunes from our web server to your laptop. You do nto need to remove teh chip from the PCM to burn to it. We supply you with all the progamming cables. You're able to try tunes before you buy them and if we add more functions or features there's no need to send it back for those updates. This is a great product for those who plan on updating their trucks or live out of the country. Never send chips back/forth for tweaks or have several different pieces of bulky equipment to reburn your chip.
__________________
Jody & Diane Tipton-FTE Legacy Sponsors since 2006
Get Tuned! 828-221-0076
Bringing quality, reliable,and safe products for your diesel truck with 100% satisfaction guaranteed! All orders ship out the next business day.
(FTE members please use discount code <FTEfreetee> at checkout for free DPT gear with purchase)
  #11 (permalink)
Old 06-26-2009, 11:02 AM
Pocket's Avatar
Quote:
Ahhh, I stand corrected then. I thought you guys were stepping away from the F-5. Thanks Diane.
__________________
Curtis
2002 F-250 PSD
Truck Pics
  #12 (permalink)
Old 06-26-2009, 01:01 PM
Thanks Mr Tipton!!.
I think the F5 will suit me just fine!! Along with aq 4" exhaust and maybe some gauges.
I'll be in touch.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
