Greasing your main wheel hub bearings. Pics here
#32
Nothing at all?
Pop
#33
Nada , nothing I was trying to see if I missed anything, we were driving through the mountains all day and not a problem, till I got in tacoma
#35
Done!! told them to grease,lube, flush, tighten and double check everything.. hate the fact that the wife and I came close to eating a divider or worst taking out another vehicle..We were doing 70+ MPH when the left front locked up.. but on the other hand, my final bill was 401.76, down from 531.00( military discount is the greatest)
#37
Unless you are willing to do your own maintenance, and truly understand what's going on, you're not likely to be getting a really comprehensive job done to your truck.
Just the way it is.
Pop
#38
You may THINK they greased your hub bearings, but unless they are reading this, or something like it, they didn't. Ford considers these bearings non-serviceable, and most everybody else does, too. That's exactly the reason we've addressed this subject here.
Unless you are willing to do your own maintenance, and truly understand what's going on, you're not likely to be getting a really comprehensive job done to your truck. Just the way it is.
Pop
Pop
#39
Then you'll have it done right!
I've lived my life with the motto, "If you want something done your way, do it yourself."
It's the only way I can be sure it gets done right.
Beside a few on this forum, I trust NO ONE to twist wrenches on my truck.
If you're under my truck with anything besides a grease gun, and you don't have a torque wrench, you'd better just slide on out.....
And, if you DO have a grease gun, you better have a good understanding of lubrication technology!
Pop
Pop
#40
Now that's the truth, heck it's even hard for me to find a good alignment shop most of the clowns just to do a tow and go, that's why I always ask for a print out before and after, I wish for an alignment rack but it never shows up.
#41
#42
My 2000 SD 4WD (130K mi.) was at the dealer today for an unrelated service and I was told that my left front hub/bearing was worn and could fail at any time...they want $750 to do the one side. I've had NO symptoms whatsoever and will ask them to show me how they came to this conclusion tomorrow. After reading this thread and hearing all the comments about greasing through the ABS hole, I'm left to ask what about a truck such as mine that does NOT have front ABS...is there a way to provide maintenance to the NON-ABS bearing assembly and is there a maintainable aftermarket assembly available?? Could a new OEM unit be modified to accept a zerk fitting? I'm guessing that I will still need to lube the needle bearings in the same manner as described in this thread? I welcome your comments...Thank you.
#44
#45
mileage failure point / maintain or replace / front & back ?
If your bearings have 130K, 140K, 150K+.... at what point is failure likely? Also, at that point would this maintenance be too late, and we would be better served with a pre-breakdown/accident replacement of these bearings?
These 3 types of bearing greasings would be for the front wheels, or for both the front and back axle?
