Spark plug change walk though
It appears I will be changing out the plugs on my 5.4 SD this weekend myself. Gator Ford wants 385.00 for 8 plugs and labor. I have never changed the plugs on this truck, it can't be that hard to do. or is it? Can some one steer me in the right direction and give me a walkthrough? I would think you pull the fuel rails then the coils then blamo you pull the plug? Or am I missing a step or two? Thanks in advance.
When I did my Crown vic with the COP's....first I did them one at a time, tried to ensure that all loose dirt was sprayed away, loosen the boot that covers the plug. You may end up destroying them so be prepared to buy new.
Then I sprayed a little WD-40 in the hole for a few minutes. Then took them out. I have heard of a few people breaking them because they are in there for such a long period of time. Guess I got lucky.
So just make sure the hole is clean before you take them out.
I also had a vacume hose handy that I could insert in the hole and grab the plug for the few that dropped in the hole when the plugs fell out of the socket..
Hope that helps some.
Many of us have had good and bad luck with the plug changes. Depending if you have the 3 valve motor or not may depend on your luck. Here are a couple of posts you can read that more specific to the 3 valve motor. You show a 97 F250 so if thats what your changing them in i don't think you will have a problem but can't see why Ford would charge that much for the 97.
https://www.ford-trucks.com/forums/8...ml#post7526675
If you read thread #6 it lists the TSB again for the 3V motor.
https://www.ford-trucks.com/forums/8...-question.html
Here's my thread on the plug change. Actually, the plug change starts on page 2, but still good reading.
https://www.ford-trucks.com/forums/8...gas-smell.html
Our new Ford COP’s, the Sultans of Spark(S.O.S.), have
been designed with both durability and performance in mind.
Please see them at:
http://www.performancedistributors.com/soscoils.htm
Quality was the main feature we stressed when we went to the
drawing board on these coils.
By the way, for those of you who only need to replace a defective coil,
our SOS Coils are available separately.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
FTE Sponsor
Milwaukee
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
05-05-2006 03:46 AM
