Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers And 5th Wheels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Towing, Trailers And 5th Wheels SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 06-13-2009, 10:33 AM
Trouble1263's Avatar
Trouble1263 Trouble1263 is offline
Trouble1263 is starting off with a positive reputation.
Have you read this thread?? If you have the time, it's worth it.
RV.Net Open Roads Forum: Dometic Refer Recall - Possible Fire Hazard -Update 2/13/07
I would be firm with Dometic in having it replaced under warranty or recall.
In post #1 of the thread, read update #5
Good Luck
__________________
Not much to see here folks,,move along!!
Duane
2001 F250 CC 172" 4x4 3.73 Lariat
6637, CCV, Isspro Gauges,Bilsteins,Mile Marker Hubs,Firestones,
4" Magnaflow SS,RDP-WW&HPX &GPR LED ,Foil Delete ,DP -NS/DT/S/80E/40T/Decel/60T/120R
  #17 (permalink)
Old 06-15-2009, 08:01 AM
mel2000f150 mel2000f150 is offline
mel2000f150 is starting off with a positive reputation.
I called Dometic and they said: The tubes can crack at anytime and the recall was just to stop the fire.
__________________
2000 F-150 scab 4x4 offroad (sold)
2003 Mazda 6s
2005 Rockwood 8240SS 26' 5er
2008 FX4 S/C Silver/Gray 3.73LS 5.4L, Prodigy brake controller, Dueler APT IV
  #18 (permalink)
Old 06-16-2009, 09:04 AM
If you read the thread I linked, many people have got Dometic to pay for the DESIGN failure..Threaten them with a call to the NHTSA.Go higher up the Dometic food chain!
__________________
Duane
  #19 (permalink)
Old 06-16-2009, 02:12 PM
So after 2 phone calls and 3 e-mails this is what I got back from Dometic:
In response to a potential safety-related problem, Dometic has initiated a recall in compliance with applicable federal regulations. A secondary burner housing, when retrofitted to affected refrigerators, at Dometic expense, resolves the identified safety problem. Dometic developed and placed secondary burner housing kits into the field through service centers throughout the United States and Canada. The secondary burner housing created by Dometic has resolved the safety issue with respect to any affected refrigerators.
Dometic is not replacing cooling units or refrigerators under the recall program. If a unit fails and is within Dometic’s original manufacturer’s warranty it is covered as part of the normal warranty repair. However, no product lasts forever, and if the unit is beyond the standard warranty and the customer has elected not to purchase an extended warranty or the extended warranty has expired: then all repairs for any failures would be the responsibility of the consumer.
Thank You
Recall Department
Dometic, LLC
__________________
2003 Mazda 6s
  #20 (permalink)
Old 06-16-2009, 08:31 PM
rvpuller rvpuller is offline
rvpuller is starting off with a positive reputation.
I had the recall done before we left for Alaska last spring and the only thing it did for us was cause a 12V electrical short when we where in the Yukon , Have you ever been attacked by 10K flying vampires while you are trying to fix something it's the biggest joke I have seen in a long time.
Denny
__________________
2000 F350 Lariat SC DRW V10 4.30 Gears BrakeSmart
Air Lifts 4X2
2003 HH Premier 35 FKTG
BSEG started 4/15/2000
Avon Park Fl for the winter 09-10
  #21 (permalink)
Old 06-26-2009, 10:38 PM
mechmagcn's Avatar
mechmagcn mechmagcn is online now
mechmagcn is gaining momentum as a positive member of FTE.
Dometic will not replace cooling units under the recall. I have replaced many of the units due to leaks and blockages. It is a fairly simple and straightforward job. I do most alone in 1 1/2 - 2 hours.
__________________
Jeff
1953 F100 PU "Someday"
Lincoln Town Car front clip
5 cyl Mercedes turbo diesel/auto
It Runs! It Even Moves!
Tags
burner , dometic , manual , repair , secondary
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
