Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-08-2009, 09:12 PM
Stickz Stickz is offline
2000 Ford F-350
Stickz is starting off with a positive reputation.
No Hot Air
Just bought an 00 F350 and went to use the heat last week and it would only blow cold air. I'm thinking most likely the mixer door not opening but I haven't had a chance to look into it yet.
Has anyone else had this issue? If so, is there something I should be looking at first (motor, vacuum, wiring,???)?
If you have any ideas please let me know.
Thanks
  #2 (permalink)
Old 06-08-2009, 10:48 PM
BareBones BareBones is offline
BareBones is gaining momentum as a positive member of FTE.
Hold the heater hoses to check for temperature differences...... Look for StopLeak in the radiator...... Does the engine idle little high, etc.
Actually, are you gas or diesel?
__________________
2005 F350 V10 6spd dually, 15K receiver. No 4WD, no LS, no A/C, no special cab - just a lean mean towing machine!
  #3 (permalink)
Old 06-08-2009, 10:55 PM
2000 Ford F-350
Both of the heater hoses seam to be around the same temp, feeling them by hand.
Sorry it's a diesel.
  #4 (permalink)
Old 06-08-2009, 11:56 PM
jim6liter's Avatar
jim6liter jim6liter is offline
jim6liter is starting off with a positive reputation.
mine blew cold and was low on coolant.Did you check that?
__________________
04'F-250 6.0 PSD.CC Dk.Shadow Gray.XLT SPORT FX4 TT Mirrors,ETC.ACETONED EMBLEMS,billet grille,Fabtech 8" all spring lift,Dual front Fox shocks with rezzies,BILSTIEN REARS,37"Toyo M/T's,Banks Monster Exhaust,cat gone,Fumoto valve
  #5 (permalink)
Old 06-09-2009, 01:59 AM
BMWM1 BMWM1 is offline
2003 Ford F-Super Duty
BMWM1 is starting off with a positive reputation.
Check for low coolant or maybe to much water and not enough coolant. Where are you at that you need heat this time of year
__________________
  #6 (permalink)
Old 06-09-2009, 08:39 AM
2000 Ford F-350
Quote:
Yes, I did check that and the coolant level is fine.
Quote:
Never thought of too much water. I'll test the coolant to make sure that is not the problem.
I'm in Ontario, near Toronto. We have been getting quite a few cold nights over the last month or so.
Seams more like nothing is happening when I turn the temperature knob from cold to hot though.
Thanks for the responses guys!
  #7 (permalink)
Old 06-09-2009, 11:58 AM
It be easier to just check the gauge and make sure the engine is warm. Probably not the best idea Ive has in a while. Im sure someone here will be of more help.
__________________
  #8 (permalink)
Old 06-09-2009, 10:06 PM
2000 Ford F-350
The coolant tested ok and the temp gauge runs at about 1/3 when the engine is warm. Is 1/3 on the temp gauge normal for this? Most vehicles I've had run anywhere from 1/3 to 1/2 but this is my first diesel.
I tried the heat again to day just to see if there was any change and the air was still blowing cold, very cold, like the A/C is on.
  #9 (permalink)
Old 06-09-2009, 10:43 PM
bohiaa bohiaa is offline
bohiaa is new and has a neutral reputation at this point.
I'm thinking the heater core is colged. does the engine temp gauge show fluxuwation
HAd an F150 that did this, also could be the tstat sticking
  #10 (permalink)
Old 06-09-2009, 10:53 PM
2000 Ford F-350
No, once the gauge reaches 1/3 it stays there.
Do these usually run hotter them 1/3 on the gauge?
  #11 (permalink)
Old 06-10-2009, 01:45 AM
Ill double check mine but I thought mine stayed around half way
__________________
  #12 (permalink)
Old 06-10-2009, 11:49 AM
2000 Ford F-350
Thanks, that would be great!
If it should be at half, then I'll have to replace the thermostat and see what happens.
  #13 (permalink)
Old 07-03-2009, 09:26 PM
2000 Ford F-350
I finally got around to looking at this last week. When the blend door wires are touched or moved the actuator would start moving the door and always sit at the half way point.
I picked up a new blend door actuator a couple of days ago and put it in tonight. That was definitely the problem, it works great now.
Thanks for the help guys.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
