Undercarriage Thumps!!!
Old 06-08-2009, 08:10 PM
holyshift17's Avatar
holyshift17
holyshift17 is offline
Smile Undercarriage Thumps!!!
My Ranger is a 1994 and i just got it a couple months ago, and i have noticed there is a thump when i give it gas or accelerate fast. could it be my ujoints or something else?
Old 06-10-2009, 06:24 PM
pc09123's Avatar
pc09123
pc09123 is offline
I had a similar problem once with a car of mine and I found out the rubber bushing that dampens the strain on the transmission had seperated and fallen off. Look on the top side of your tranny and there should be a bolt that fastens to the cross member of the chassis. What you might be hearing is the tranny thumping up against the cross member. Worth a look at least.
Old 06-10-2009, 08:48 PM
GrayRanger4x4's Avatar
GrayRanger4x4
GrayRanger4x4 is offline
If you have a 2 piece drive shaft the slip joint probable needs to be cleaned and regressed.Replacing the joints and support bearing would be good idea while you got the DS out.If its the 1 piece DS then pc9123 is on the right path.
Old 06-13-2009, 10:14 PM
diamonddave242's Avatar
diamonddave242
diamonddave242 is offline
FYI,
I just changed my U-joints. One was bad. Then drained the differential fluid for maintenance, and noticed that the "spider gears" were worn. It turn out that the clunking that I heard when I accelerated came from this area.
lylino
Escape & Escape Hybrid
08-20-2009 03:59 PM
CanadianSmokie
01-27-2009 04:42 PM
tebby
1997-2006 Expedition & Navigator
06-17-2008 11:21 AM
scar98
10-31-2005 09:21 AM
Quick Reply: Undercarriage Thumps!!!
