56 F100 not charging
Thats a small question with a huge answer! If there is a problem, it's either the generator, the regulator, or hook-ups (like circuit breaker shunts, etc).
If you have a shop manual, perform the test for bypassing the regulator and measuring generator output (by connecting a jumper between the ARM and FLD posts on the generator - but read the procedure). If the output at 1500 rpm is 35 amps, replace the regulator.
Here's a link to read. I quote the procedure there if you don't have a shop manual (and if you don't I would suggest very strongly that yo uget one) - post #3:
https://www.ford-trucks.com/forums/7...regulater.html
PS. If you read farther down you will see a question about "polarizing" the generator. My answer was incorrect (bad day), as the part that is getting polarized is the field windings in the generator itself - so there is no need to polarize if you replace the regulator, but you do need to polarize if you change the generator.
