Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-08-2009, 06:31 PM
Dutch123 Dutch123 is offline
Dutch123 is starting off with a positive reputation.
Switch Power- Source?
Installing driving lights- have a lead (according to directions)for "switch power" What/where is the source for this?
Thanks-
__________________
Thank you;
Dutch
1996 XLT 5.8 351W
Gibson sideswept single out exhaust
Bassani Y-pipe and ceramic headers
BBK Twin 56mm TB
  #2 (permalink)
Old 06-08-2009, 07:54 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all
What is the total wattage of the lights, and how do you want them to work, i.e. do you want them to come on with the headlights, or have a separate switch for them? Do you want them to work with or without the ignition being on?
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 06-08-2009, 08:38 PM
Ok- 100w total; would like these to work independent from the headlights- but with ignition on. (Separate switch I have)
Dutch
__________________
Thank you;
Dutch
1996 XLT 5.8 351W
BBK Twin 56mm TB
  #4 (permalink)
Old 06-09-2009, 10:48 AM
Franklin2's Avatar
100w at 12v = 8.3 amps. The best way to do this is mount a bosch type foglamp relay under the hood near the battery. Hook a inline fuse rated around 15 amps to the battery +, and then run this to the relay contact. Come out of the other relay contact and run to the lights. Use at least a 14 gauge wire for these connections.
For the coil of the relay, hook one side of the coil to a metal ground near the relay. Connect another wire to the remaining coil terminal, and run this all the way inside cab to your switch. Come out of the other side of the switch with another wire, and run this to the fuse box. Go buy some little gizmos they call "fuse taps". This will let you hook the wire from the switch into the fuse box. Pick something that is only on with the ignition on, such as the radio or possibly the blower motor. That will let the lights only work with the key in run, though if you hook it to the radio fuse, they might also work in acc position too.
__________________
Dave F
  #5 (permalink)
Old 06-09-2009, 02:29 PM
"fuse taps"- that's something I need to know... I diagrammed out your explanation and it is doable. So, am I supposed to add the 8.3 amp draw to whatever I fuse tap it to- and make sure I do not go over a certain fuse rating. Say a 15amp fuse for the radio- but what does the radio draw 11amps- so add these 8.3 and 11 (estimated) which is 19.3 so I need at least 20amps- Is my thinking on the right path here.
getting ready for shuttle lauch 6-15-09
Dutch
__________________
Thank you;
Dutch
1996 XLT 5.8 351W
BBK Twin 56mm TB
  #6 (permalink)
Old 06-09-2009, 03:04 PM
f250ssd f250ssd is offline
f250ssd is starting off with a positive reputation.
Here is a diagram with relay hookups that I drew for somebody else.
You could hook up the switched power to something that only comes on when you turn the ignition. With a relay hookup you don't have to worry so much about the current draw of what you hook up the switched power to, because the relay coil only uses about 150 milliamps.
The picture I drew is for an eight light system, but one of the relays there, is for two lights.
  #7 (permalink)
Old 06-09-2009, 08:56 PM
Ok- I've got what I need
__________________
Thank you;
Dutch
1996 XLT 5.8 351W
BBK Twin 56mm TB
  #8 (permalink)
Old 06-29-2009, 06:27 PM
happylogan1 happylogan1 is offline
happylogan1 is starting off with a positive reputation.
BTW- Ran into a snag; obviuosly need to run wire assembly from engine bay into the cab. I have a 3/8" male-female connector (rectangular) that needs to find it's way. Should I drill this diameter hole- or bore out to this diameter an existing hole which currently is passing wires into the cab?
Cranks
  #9 (permalink)
Old 06-29-2009, 08:16 PM
Franklin2's Avatar
It's already made up on the underhood end? I guess you have already checked if you could undo this end and route the wire through the firewall from the inside, if the connector is going to end up being on the inside.
Otherwise, I guess a 3/8 hole is going to be required. They are a little bit expensive, but you can go to the store and buy what they call a "uni-bit". It's a stepped looking drill bit that makes a beautiful hole in sheetmetal.
__________________
Dave F
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
