Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-08-2009, 03:48 PM
dirtybroncoii dirtybroncoii is offline
dirtybroncoii is starting off with a positive reputation.
Odd Starter issue
I have read some of the threads on here trying to figure out what is exactly wrong with my truck.
Here is the issue.
I install the starter and ill only get maybe 5 starts off of it before it starts to grind on the flywheel. When I loosen the starter up and re torque it I can get 5 starts off it again.
Here is what I have done so far.
Changed starters (3x), Changed the Flywheel (3x), Changed Bell Housing (2x). every time I changed one major component I tried the other minor ones. I have tried all 18 of the possible combinations of all the parts I own and it does the same thing every time. Basically I have replaced everything between the engine and the transmission and I cant seem to figure out what is wrong.
The only thing i can think of is the transmission its self needs to be replaced but I didn't have any troubles with this transmission in my other Bronco II. As for the engine it is a fresh rebuild begging for some miles. Im at the end of my knowledge base if anyone could help it would be much appreciated.
__________________
1987 Bronco II Eddie Bauer
Bored and ported 2.9L Now a 3.0
Stock 5sp. and Stock BW 13-50 Transfer case
  #2 (permalink)
Old 06-09-2009, 01:43 PM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
Is the spacer plate installed between engine and transmission? Only other thing I can think of is you have the wrong starter(s) - the auto and manual transmission starters are different, if memory serves. Only other thing I can think of is to shim the starter a little at a time until you find the sweet spot and get rid of the issue(s).
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
  #3 (permalink)
Old 06-09-2009, 05:39 PM
I have used starters off of both the starter off the auto that came out of the vehicle and the 2 other manual starters that i have. I have tried shimming the starter out and all it does is grind. . . it seems like the starter gear is too short. The plate is in between the engine and the transmission.
__________________
  #4 (permalink)
Old 06-20-2009, 10:53 AM
A few friends of mine suggested it could be electrical. So I have replaced the Positive from the Battery, Starter Solenoid, and Cable going to the starter. That was all in the last few days. Nothing solved the problem.
Today I will put in a ground cable directly to the starter on the top bolt and if that dosent work i will install a 302 starter and see if it solves anything.
I have looked at the 302 starter and it has the same amount of teeth and the mounting bolts are in the same places. The only difference is that the starter is going to be mounted "upside down" compared to the 2.9 starter.
I will update when i get some results.
  #5 (permalink)
Old 06-20-2009, 10:57 AM
Quote:
I checked a few auto parts stores and have found only one starter that can be purchased and that one goes on both Auto and Standards
__________________
  #6 (permalink)
Old 06-20-2009, 11:06 AM
tommyleea tommyleea is offline
tommyleea is starting off with a positive reputation.
History? Was the starter the original problem, and what was the original starter symtoms? Were the flywheel and other parts replaced because of the starter problem, or prior to? Just trying to narrow down the possiblities.
TommyJ
  #7 (permalink)
Old 06-20-2009, 02:49 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 is gaining momentum as a positive member of FTE.
How bad are the teeth of the starter and ring gear? You might not be engaging the bendex at all. I never heard of shimming Ford starters before unless you had a bent bellhousing or bent bolts holding starter in place.
__________________
89 F250 2x4 302/AOD 4.10 gears ,now on road.
89 Bronco2 with dead A4LD again
84 F250 4x4 300/np435 3.55 gears. The BLUE MULE shut down due to cab cancer(looking for good cab)
95 E350 bus conversion 460/E4od 4.10 the new toy!
85 Plymouth Caravelle 2.5L someday to get the hairdryer treatment(turbo)
93 explorer now just a woods buggy
  #8 (permalink)
Old 06-20-2009, 04:42 PM
tommyleea: - History: The vehicle started out running and driving great, until the day the front seal went out in the automatic in it. I took the original engine and transmission out and replaced with my Fresh rebuilt 2.9 and the manual that was with it in my other Bronco II. That engine NEVER had a starting issue it ran just great too.
Eddiec1564: - All 3 flywheels and all 3 Starters have the same amount of teeth on them, also if I try to shim the starter it DOES NOT engage at all. I have had both of the standard transmissions and flywheels behind the same engine that is currently in my truck and have had NO problems with either paring.
I just need to be driving it.
__________________
  #9 (permalink)
Old 06-20-2009, 07:11 PM
i took the aluminum plate out from between the engine and transmission and i got a few more starts out of it before it started to grind. . . but i think all the grinding that has gone on with trying to figure out this problem has wore the flywheel down so i have to replace it before i can go further.
__________________
  #10 (permalink)
Old 06-20-2009, 10:11 PM
That is what my question was about, the teeth condition of starter and flywheel. On my B2 with the A4ld, I had a grinder for a starter, it ate up three places along the flexplate(compression stroke of engine where torque of starting is highest). After replacing flexplate/starter I had no problems till that seal blew out..... I would put a manual in but the wife can't drive stick.
__________________
  #11 (permalink)
Old 06-21-2009, 01:26 AM
rebocardo rebocardo is offline
rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold
Check your pilot bearing when you have it apart. Look inside and see if anything sharp is sticking out (don't cut yourself), then stick your finger inside and give it a whirl and see if it moves freely.
If it has gone bad (welded up) not only will it require more torque to turn it over, but, it will eventually cause a front seal leak from it being cranked to the side and from vibration.
If it was bad and you did not check it, it is possible a piece dropped in front of the input shaft so the transmission is not seated all the way into the crankshaft. So, the starter is misaligned.
Had something like this happen in a customer's Jeep and AX-15 manual transmission and had to cut the bearing out with an air chisel.
So, if I had changed everything but the pilot bushing, I would pull the bushing, clean the hole out well, and install another well greased one.
__________________
The Year 2009 Anno Domini -
May it bring a great year of Revelations to you.
  #12 (permalink)
Old 06-21-2009, 03:53 PM
rebocardo: "it will eventually cause a front seal leak from it being cranked to the side and from vibration." - The front seal that went out on the previous transmission and it was an Automatic. I have never had a Standard shift leak fluid and my current transmission is not leaking.
__________________
  #13 (permalink)
Old 07-08-2009, 04:32 PM
rebocardo - How can a misaligned pilot bearing cause the starter to misalign. If the transmission is bolted tightly to the engine the starter is going to be in the correct spot.
__________________
  #14 (permalink)
Old 07-10-2009, 08:34 AM
You stated that if you loosen the starter up, and retighten it, then it will start fine again. Is the starter moving from its original position? Are the bolts actually tightening up against the starter? Maybe you need some new bolts. Cheers
TommyJ
  #15 (permalink)
Old 07-10-2009, 08:50 AM
Ok I actually fixed it. all the flywheels I own where worn to the point where the starters just stopped engaging. I had a new ring gear installed in one of my flywheels and it works like a charm. Thanks for all your input.
__________________
Tags
29 , 87 , auto , bent , bronco , engage , flexplate , flywheel , ford , ii , manual , sbf , spacer , starter , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
