Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 07-10-2009, 03:54 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Eddiec1564 View Post
How bad are the teeth of the starter and ring gear? You might not be engaging the bendex at all. I never heard of shimming Ford starters before unless you had a bent bellhousing or bent bolts holding starter in place.
__________________
Wore out teeth.... does it every time. Again make sure your starter bendex gear teeth are good as a bad ring gear WILL EAT UP a new starter which inturns WILL EAT UP the new ring gear! Been down that road with a cheby... only to find a spun bearing after...
__________________
89 F250 2x4 302/AOD 4.10 gears ,now on road.
89 Bronco2 with dead A4LD again
84 F250 4x4 300/np435 3.55 gears. The BLUE MULE shut down due to cab cancer(looking for good cab)
95 E350 bus conversion 460/E4od 4.10 the new toy!
85 Plymouth Caravelle 2.5L someday to get the hairdryer treatment(turbo)
93 explorer now just a woods buggy
  #17 (permalink)
Old 07-11-2009, 12:21 AM
dirtybroncoii dirtybroncoii is offline
dirtybroncoii is starting off with a positive reputation.
well without having anything to measure them with and no reference point they all looked good. . . compared to each other.
__________________
1987 Bronco II Eddie Bauer
Bored and ported 2.9L Now a 3.0
Stock 5sp. and Stock BW 13-50 Transfer case
  #18 (permalink)
Old 07-11-2009, 12:49 AM
99whiteford's Avatar
99whiteford 99whiteford is offline
99whiteford is starting off with a positive reputation.
I tell you something else abotu your type of problem.I'll bet that every starter you have had has a 9 tooth bendix.in some of the broncos ford used a 10 tooth.I own a starter/alternator rebuild shop and have been down this road before.sad thing about this is that know body even has a listing of has or any idea about this difference.I had a customer bring a starter in for rebuild I replaced the bendix with out checking his old one.
when he installed the starter and tried to start his truck he has serious problems.when he returned unit I could find nothing wrong.luckily I had not thrown his old one away .when i started checking things closer I discovered my error.when i put the ten tooth in his problem was solved.
__________________
06 F -350 Crew Cab
00 F-150
03 Harley Ultraglide
29 foot Jayco Quest F'ver
Its better to keep your mouth shut and let others think you're fool,than to open it and remove all doubt
  #19 (permalink)
Old 07-11-2009, 01:12 AM
all my starters are 9 tooth and i just replaced the flywheel and all is right again
__________________
  #20 (permalink)
Old 07-21-2009, 04:59 PM
greenbullitt greenbullitt is offline
greenbullitt is starting off with a positive reputation.
Quote:
Originally Posted by dirtybroncoii View Post
Ok I actually fixed it. all the flywheels I own where worn to the point where the starters just stopped engaging. I had a new ring gear installed in one of my flywheels and it works like a charm. Thanks for all your input.
make sure you put the block plate in. not using it may kill another starter eventually or worst case knock out the crank thrust in the engine
Tags
29 , 87 , auto , bent , bronco , engage , flexplate , flywheel , ford , ii , manual , sbf , spacer , starter , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
