rear drum to disc conversion kits? - Ford Truck Enthusiasts Forums
Old 06-08-2009, 11:55 AM
aguitarestv aguitarestv is offline
aguitarestv is starting off with a positive reputation.
hi all, i have a 97 f250 heavy dudy 5.8L (old body style) with the 8 lug pattern. my question is, is there a rear drum to disc conversion kit for my truck? cant seem to find one and its almost time to do the rear brake, and would hate to use drums again!
Old 06-08-2009, 11:59 AM
concreteman0 concreteman0 is offline
concreteman0 is starting off with a positive reputation.
i think that summit racing has one i seen on there web site with every thing needed to do the job i was thinking about doing that to my 93 f150
Old 06-08-2009, 12:49 PM
goodB0Y goodB0Y is offline
goodB0Y is gaining momentum as a positive member of FTE.
I seen a kit on the net... it used eldorado single piston calipers and rotors off of some other car... looked way to small and cheesy for my liking...
Old 06-08-2009, 12:52 PM
sgsavvy sgsavvy is offline
sgsavvy is starting off with a positive reputation.
looked alright to me but am not sure whether its safe
Old 06-08-2009, 12:59 PM
here's the link to the one I found...
'85-'98 Ford Sterling
Old 06-08-2009, 01:03 PM
SaikotikGunman's Avatar
SaikotikGunman SaikotikGunman is offline
SaikotikGunman is gaining momentum as a positive member of FTE.
Intrigued, now...
Old 06-08-2009, 04:48 PM
looks like a 1/2 decent kit
Old 06-08-2009, 05:08 PM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel has a good reputation on FTE.Blue Rebel has a good reputation on FTE.
Four Wheeler did an article on this a while back, when it comes time for me, im gonna go w/ the kit they used:
1989 Ford F-250 Disc Brake Installation - Four Wheeler Magazine
I know they did theirs on an 89, but it will all work on your 97
Old 06-08-2009, 06:45 PM
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
Might anyone know the thickness of the caliper mounting plates?
Old 06-08-2009, 06:49 PM
Quote:
the kit used in the four wheeler article is the same one I posted a link too...dont know if they give the specs of the mounting plate though...
here's the link again:'85-'98 Ford Sterling
Old 06-08-2009, 10:37 PM
still the only kit i could find, little pricy at 750 or so, kinda sceptical about using old cadillac eldarado calipers, but i am sure its still 5x better than the crappy drums
Old 06-08-2009, 10:43 PM
What I want to know is why they didn't design a kit around Ford truck calipers and rotors, so it'd have the same parts front and rear.
Old 06-08-2009, 10:50 PM
clearance issues maybe? if you look at the kit it just looks like swiss cheese flat stock. looks like it calliper bracket can be used with other kits. could prob. make one yourself if you could cut that thick of flat stock?
Old 06-08-2009, 10:52 PM
You'd probably have to use the bolt-on calipers from whenever they switched from the pins, but I don't see why they couldn't cram it in there. If I had a plasma cutter, I've got the stock. Not going to burn up a hundred Sawzall blades cutting out brackets just to try it.
Old 06-08-2009, 11:00 PM
hmmm know anyone with a band saw? dont think my small carpenters one would handle it(even if i could find a metal blade for it)
1995 F150 Rear drum to disc conversion? W1d0wmak3r 1987 - 1996 F150 & Larger F-Series Trucks 12 06-11-2014 09:47 AM
1979 f-250 FRONT disc brake conversion? bigdan1979f-250 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-07-2013 02:32 PM
Drum to Disc conversion? mroberts91 1973 - 1979 F-100 & Larger F-Series Trucks 1 04-14-2011 12:39 AM
Rear Disc Brake Conversion 94 f350 Happyreefer Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 12-02-2007 10:55 PM
2000 ranger rear disc conversion thecheat508 Ranger & B-Series 8 09-05-2006 05:49 PM
Tags
1996, 89, 93, 97, brake, conversion, disc, drum, drumtodisc, f150, f250, f350, kit, kits, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
