Knock sensor location 4.6 - Ford Truck Enthusiasts Forums
Old 06-08-2009, 11:41 AM
firmin72397 firmin72397 is offline
firmin72397 is starting off with a positive reputation.
98 F150 4.6 liter
Where exactly is the knock sensor on these engines? Is it different between the Windsor and Romeo blocks? I have my manifold off and there is a sensor right in the middly of the valley, but everyone and everything I read says it's off to the passenger side. It is screwed into a nut right slap in the middle of the lifter valley, and there is copper showing on one of the wires right where it comes out of the epoxy on the switch. Any help identifiy if this is indeed the knock sensor would be greatly appreciated.
Old 06-08-2009, 05:23 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
Welcome to FTE firmin72397! that certainly sounds like the knock sensor to me. Good luck!
Old 06-09-2009, 10:56 PM
CharlieBravo CharlieBravo is offline
CharlieBravo is starting off with a positive reputation.
Yep. That is the knock sensor.
knock sensor location topcopsr 1999 to 2016 Super Duty 8 11-16-2015 02:14 PM
swap tsmithstur 1997 - 2003 F150 0 03-22-2015 10:32 PM
solid motor mounts Ziegelsteinfaust Engine Swaps 0 03-19-2015 07:10 PM
02 explorer 4.6 spark knock??? trvctyrich Explorer, Sport Trac, Mountaineer & Aviator 5 12-09-2011 04:03 PM
knock sensor ole88 1987 - 1996 F150 & Larger F-Series Trucks 2 12-04-2011 07:57 AM
Tags
2001, 2002, 2003, 46, 97, e150, engine, f150, ford, knock, knok, lightning, location, ltr, sensor, svt, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
