Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-08-2009, 12:36 AM
saint1 saint1 is offline
saint1 is starting off with a positive reputation.
460 into 73 390 F350 Super Camper Special question
Hello, I own a 73 F350 Super Camper Special that originally had a 390 and I Am swapping in a 460 from a 76 Econoline Chgateau Van. The 460 and C6 from the Van were completely built for Towing a race trailer and have 5 K miles on the set.What all do I have to change and whats the easiest way to do the swap. Here is what I know is this correct so far. 1.) I need to swap oil pans to a 2wd truck 460 oil pan 2.) relocate the dipstick to the timiming cover 3.) Radiator should be same correct?? I have the desert Rad. 4.) The 460 had Electronic ignition so I have to change the electrical? The old 390 was points-how do I do this? 5.) The engine mount Perches have to be changed to the perches from a 73-77 460 2wd perches and mounts--what all really needs to be done.?? Any help is greatly appreciated. Wayne
  #2 (permalink)
Old 06-27-2009, 09:34 PM
junkyardjeff junkyardjeff is offline
junkyardjeff is starting off with a positive reputation.
Just find you a parts truck with a 460 and you will have everything you need,you might be able to get by with the rear sump pan from the van and the van radiatior might work. Where are you located as a local junkyard had a 77 F150 with a 60 a few weeks ago and the duraspark system is easy to wire up,find a chiltons manual with wiring diagrams and you should be able to wire up the duraspark from the van in the 73.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
