95 F-150 Coil Spring Problem - Ford Truck Enthusiasts Forums
Old 06-07-2009, 10:05 PM
macintyremustang macintyremustang is offline
macintyremustang is starting off with a positive reputation.
Hi Guys, I am having a coil spring problem and I am hoping for a solution. I was reading on here that 2wd F-350 460 V8 springs could be put in an F-150 4x4 to achieve a bit of a lift so I went out and bought a pair.
The trouble is I am now having difficulty getting them to fit. The springs hit against the ball joint nut. The alignment shop can't complete the alignment because the spring rubs against this adjustment point. I tried putting the springs every which way without any luck. My alignment guy has 30 years experience and he said there is no way the springs will work binding against that nut because he can't adjust it.
Anyway, at this point I am thinking they will not work. But I am hoping for a miracle. I am out $246 total with the trips to the alignment shop and money is running out. Thanks in advance. Here is what I bought from Napa:
******** language="javascript"> function ViewImage() { var imgSrc = (document.getElementById('PartImage')).src; var newWindow = window.open(imgSrc, 'popup_win', 'width=450, height=450,toolbar=0, location=0,directories=0,status=0,menuBar=0,scroll Bars=0,resizable=1'); newWindow.focus(); } function SetImage(obj) { var imgUrl = obj.options[obj.selectedIndex].value; var imgTag = document.getElementById('PartImage'); imgTag.src = imgUrl; } *********> <table border="0" cellpadding="3" cellspacing="0"><tbody><tr valign="top"><td colspan="6">Coil Spring - Front
</td> </tr> <tr id="ctl00_mainContent1_ucHTMLContent_ctl00_TrNoDet ail"> <td id="ctl00_mainContent1_ucHTMLContent_ctl00_TdNoDet ail" colspan="6" align="center" valign="middle">
</td> </tr> <tr id="ctl00_mainContent1_ucHTMLContent_ctl00_trDisco unt"> <td id="ctl00_mainContent1_ucHTMLContent_ctl00_tdDisco unt" colspan="6" align="right" valign="middle">
</td> </tr> <tr valign="top"> <td></td> </tr> <tr valign="top"> <td valign="top"> <table border="0" cellpadding="0" cellspacing="0"> <tbody><tr height="120"> <td align="center">
</td> </tr> <tr> <td> <center>Click on image to see enlarged view</center>
<input value="28589088" name="prrfnbr" type="hidden">
</td> </tr> </tbody></table> </td> <td></td> <td> Item#: NCP2775388
Price: $114.00
tax and shipping not included
Disclaimer: The stated price may vary from the in store price and may change at anytime.
Attributes:
Features & Benefits:Coil Springs Support Vehicle Load & Maintain Ride Height For Proper Alignment.
Features & Benefits:Precision Engineered Coil Springs Are Supplied In Matched Sets.
Features & Benefits:Variable Rate Coil Springs Provide Additional Load-Bearing Capacity.
Features & Benefits - 2:Worn Coil Springs Cause Poor Handling
Improper Alignment & Unnecessary Wear On Tires & Suspension Parts.
Type:Two Pigtail Ends
I.D.:4"
Load Height:13"
Free Height:15.8"
</td> <td></td> <td></td> <td width="150">
</td> </tr> <tr valign="top"> <td colspan="6"></td></tr></tbody></table>
Old 06-08-2009, 01:53 AM
9.ford.5's Avatar
9.ford.5 9.ford.5 is offline
9.ford.5 is gaining momentum as a positive member of FTE.9.ford.5 is gaining momentum as a positive member of FTE.
post some pics of the setup on the truck if possible...there might be something else going on cause from what i know they should fit (someone correct me if im wrong) without issues and they should also ride about 2" higher
Old 06-08-2009, 01:46 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm Ohio Ford Farm is offline
Ohio Ford Farm is gaining momentum as a positive member of FTE.Ohio Ford Farm is gaining momentum as a positive member of FTE.
almost sounds like you forgot the cups on the bottom of the springs? If I recall correctly the bottom of the spring should sit about 1 or 2 inch above that nut. If your old springs did not touch the new ones should not as well. AS before please post a picture of the springs mounted then maybe we can see whats wrong here.
Old 06-09-2009, 08:49 AM
Thanks I will post some pictures tonight when I get home.
Old 06-09-2009, 10:30 AM
mstngmikegt's Avatar
mstngmikegt mstngmikegt is online now
mstngmikegt is starting off with a positive reputation.
curious about seeing pics and solution...have considered doing this swap on my truck.
Old 06-09-2009, 08:12 PM
Old 06-09-2009, 08:13 PM
Old 06-09-2009, 08:15 PM
Old 06-09-2009, 08:16 PM
Old 06-09-2009, 09:16 PM
Here is the Ford diagram. I replaced part # 24 "Front Spring Insulator". It seemed to go around part #23 "Lower Spring Seat". Then I reattached the Retainer and nut # 20 and # 21 on the diagram. I tried switching the springs from the RH to LH sides thinking I had them on the wrong side, but that did not help. It looks like the springs cannot be flipped due to the way the nut holds them down. Also I can't seem to turn the springs any other way or they hit the quad shocks. Any ideas would be very helpful! Thanks.
Old 06-09-2009, 09:24 PM
Here is the only picture I have of the truck on my computer right now. The snow is gone now... You can see how low it was on the front with a broken original coil spring.
Old 06-09-2009, 09:38 PM
dbuck50 dbuck50 is offline
dbuck50 is starting off with a positive reputation.
I wonder if the springs are the right ones? I did the same thing on my 93 F150. I used the same year F350 springs. Just a thought, I used the regular F350 springs, not the sever/heavy duty ones which had a couple hundred pounds extra capacity but the same height I think.
Old 06-09-2009, 09:45 PM
Yes, these springs are 95 F-350 460V8 Severe Duty Springs. Maybe I should have got the non severe duty springs, but someone on here said they used severe on another post, when I asked about doing the swap.
Old 06-09-2009, 10:12 PM
PatsPOS PatsPOS is offline
PatsPOS is starting off with a positive reputation.
Man, that's a tough one! I've done the same swap on my half-ton (not with NAPA springs...I got Spicer units from RockAuto, but they're roughly all the same), and I have about a quarter-inch of space between my upper ball joint nut and the spring. I don't think I have any GOOD suggestions...the only thing I can think of is maybe loosen (don't remove) the lower retainer nut and try to pry the bottom of the spring in toward the center of the truck. Or maybe a good swift kick would do the trick...maybe (and I'm guessing here) the bottom of the spring isn't properly centered on the seat.
Pat
Old 06-09-2009, 10:32 PM
Thanks Pat! I'll give it a try. I've had the springs off and on many times, but you never know.
Mac
Line Lock lafermedavid 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-09-2013 02:48 PM
FAQ - Dana axle service manuals (off site) ctubutis '80-'86 FAQs (Frequently Asked Questions) 0 02-08-2011 10:35 PM
Am I missing anything on this Oasis? morrisjl2 General Diesel Discussion 5 04-30-2009 04:00 PM
I have a timing problem!! Questions.... fishindave11 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 8 11-16-2008 03:27 PM
my oasis report indebt 1999 - 2003 7.3L Power Stroke Diesel 7 11-07-2008 10:29 PM
Tags
4x4, 95, aligning, bad, bottom, bucket, coil, f150, face, seat, spring, springs, symptoms, truck, worn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
