Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 06-30-2009, 07:57 PM
ottawaguy's Avatar
ottawaguy ottawaguy is offline
ottawaguy is starting off with a positive reputation.
No need to get your panties in a bunch.
These aren't my comments...they are facts. I cannot explain what happened in your situation, but a bad brake booster should not cause a pedal to go to the floor.....just the opposite.
Google is your friend...don't be afraid to check if you don't believe me.
__________________
Dave
1994 F-150 XL Supercab 4x2 300CID-I6
1994 Bronco XLT 4X4 302CID-V8
  #17 (permalink)
Old 06-30-2009, 08:20 PM
fromm's Avatar
fromm fromm is offline
fromm is starting off with a positive reputation.
I have replaced the brake master cylinder. That was the first thing after the wheel cylinders and new brakes and hardware kit. I bled the brakes (all wheels) and the pedal builds up pressure. Then when you start it the pedal falls to the floor when you push it.
It does make a hissing sound when you push the pedal but I didnt think that was anything to worry. Will the hissing sound when you apply the brakes cause any trouble
  #18 (permalink)
Old 06-30-2009, 08:24 PM
andym's Avatar
andym andym is offline
1990 Ford Bronco
andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future
A bad brake booster can never cause a low, soft, or sinking pedal. The only thing it will ever do is cause the brakes to be very hard.
__________________
Andy
Quote:
Nothing is obscene if we only close our eyes
  #19 (permalink)
Old 06-30-2009, 10:37 PM
fromm's Avatar
I didnt think a bad booster could have caused my problem after reading how the work.
I have read on different sites that you have to bench blead the master cylinder before putting it on, (which makes sense)
and that if not bench bled it could take a long time to blead. Also that some times it wont blead at all.
Is this true.
  #20 (permalink)
Old 06-30-2009, 11:03 PM
ottawaguy's Avatar
Well, if you did install a MC and did not bench bleed the MC first, then you have some more bleeding to do I suspect.
If you have a new MC and it is not defective and you have no leaks in the system, then you problem is indeed air in the system.
When bleeding your brake system, always start at the wheel that is farthest. so, you would start with the right rear, then left rear, right front and finally left front.
Make sure you keep the reservoir topped up throughout the bleeding process.
__________________
Dave
  #21 (permalink)
Old 07-01-2009, 07:38 PM
fromm's Avatar
Well it is a new Master cylinder, but I cant be sure its not defective. I have bought many new parts from autozone and oriellys that was defective
We didnt bench bled it before installing. So how much air would you say could be in the line.
  #22 (permalink)
Old 07-01-2009, 07:42 PM
ottawaguy's Avatar
Hard to say really....but if you bled all your lines after installing the new MC, you likely have air in all your lines now.bleed in the order I stated and keep bleeding till you see no trace of air. You must have air trapped somewhere...
__________________
Dave
  #23 (permalink)
Old 07-01-2009, 09:52 PM
fromm's Avatar
Alright I will try it again and get back with you in a couple of days or so. Thanks for the info.
  #24 (permalink)
Old 07-01-2009, 10:00 PM
ottawaguy's Avatar
No worries.....hope all turns out well.
Patience is the key.
__________________
Dave
  #25 (permalink)
Old 07-02-2009, 04:36 PM
1980F15049 1980F15049 is offline
1980F15049 is starting off with a positive reputation.
brake booster, master cylinder, check for leaks in rear drums(bad wheel cylinders)
  #26 (permalink)
Old 07-02-2009, 05:16 PM
fromm's Avatar
1980f15049:
Like I said I have replaced master cylinder and rear wheel cylinders
  #27 (permalink)
Old 07-02-2009, 08:33 PM
ottawaguy's Avatar
Quote:
Good Answer!
Did you read any of posts other than the first?
__________________
Dave
  #28 (permalink)
Old 07-02-2009, 10:16 PM
Aciancio's Avatar
Aciancio Aciancio is offline
Aciancio is starting off with a positive reputation.
If you didn't bench-bleed the master you will never get all the air out of the system. you can still bench-bleed it with it in the truck. you will need 2 people, one in the truck and one at the MC. the new master should have come with a bleeding kit (2 nipple fittings, some plastic hose, and a holding clip (maybe)). disconnect the brake lines, screw the fittings into the master then run the hose from the fittings into the reservoir, now have one person slowly pump the brakes while the other watches the tubbing for air and adds fluid if needed. when there is no air in the lines pump the brakes 5-6 more times to make sure then remove the fittings and reattach the brake lines. then start the truck bleeding all over again starting at the pass. rear and working up to the driver front. good luck
oh ya one last thing, did the 86 have ABS?
  #29 (permalink)
Old 07-03-2009, 07:30 AM
fromm's Avatar
I dont think that it has abs but i cant remember. But if it does have abs is there something I need to do different
  #30 (permalink)
Old 07-03-2009, 12:46 PM
andym's Avatar
1990 Ford Bronco
No ABS on an '86.
__________________
Andy
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
