Excursion Rear Glass Fell Out - How to Reattach?
Old 06-07-2009, 04:32 PM
bulletpruf's Avatar
bulletpruf
bulletpruf is offline
Fellas,
Pulling into my driveway today and the rear pane of glass just fell out of my 2003 Excursion. This is the glass that you can open with a switch on the dash - hinged, so it will open in the back to vent out hot air. Surprisingly enough, the glass didn't shatter, so I want to reattach it. The adhesive that was holding it on obviously failed.
Any ideas on how to reattach? Suppose it's some kind of heavy duty adhesive; I don't think duct tape is going to do the trick. Also, how do you hold the window in place while the adhesive cures? I'd rather not bring it to the dealer unless I have to.
Thanks!
Scott
Old 06-07-2009, 04:37 PM
BAJI26's Avatar
BAJI26
BAJI26 is offline
There is a thread that the samething happened to someone!
Old 06-07-2009, 04:48 PM
EXv10's Avatar
EXv10
EXv10 is offline
I doubt if the dealer is the silver bullet. If you want to attach it permanently I would use contact cement. It comes in a can and you can wait until the directions says to attach it and; Done!.
Old 06-07-2009, 06:41 PM
wallz's Avatar
wallz
wallz is offline
The glass is installed with a 2 part epoxy. You can either take it to a glass shop to have them install it, or just see if you can purchase an epoxy kit from them. The epoxy will set in a few minutes so you will want to be ready to slide the glass in place and either hold for a few minutes or use some of the green drywall safe painters tape to hold it in place, or even electrical tape. Some will use duct tape or the red sheating tape, that will leave a residue on the body and is a pain to remove after.
Old 06-07-2009, 07:01 PM
VaSheriff's Avatar
VaSheriff
VaSheriff is offline
If I was doing this..... I would indeed use duct tape, for it's strength. And I would let it sit overnight to
dry very well. Simple car wax, any brand, will take the residue from the duct tape off very easily.
Old 06-07-2009, 07:16 PM
EXv10's Avatar
EXv10
EXv10 is offline
Contact cement
Old 06-07-2009, 07:39 PM
cbradford's Avatar
cbradford
cbradford is offline
You need the epoxy kit as wallz said or it will fall out again and next time you may not be so lucky.
Old 06-07-2009, 07:44 PM
wallz's Avatar
wallz
wallz is offline
The problem with the duct tape is it has a tendency to sometimes take some of the clear coat off as well when it is peeled off. I have seen it all in the last 14 or so years as a glass installer.
Old 06-07-2009, 08:46 PM
bulletpruf's Avatar
bulletpruf
Headed to the dealership and then a glass place in the morning. Here's the problem - there is a molded piece of plastic that attaches to the glass - it has a female fitting in it that is partially broken - that's why the glass fell out. I'm betting that this piece is not sold separately; probably have to buy the entire piece of glass to get that. However, I think with some plastic welding and a hose clamp, I may get it to hold.
Of course, if the glass is not too expensive, I'll just buy a new one.
Thanks,
Scott
Old 06-07-2009, 08:52 PM
EXv10's Avatar
EXv10
EXv10 is offline
Don't forget about the wrecking yard.
Old 06-07-2009, 09:31 PM
VaSheriff's Avatar
VaSheriff
Thanks,
Scott
All of the OEM ford parts web sites say this.....
<TABLE class=tabletext cellSpacing=0 cellPadding=3 width="100%" align=center border=0><TBODY><TR><TD class=tabletext style="BORDER-TOP: #24569d 4px double; BORDER-BOTTOM: #24569d 4px double">Description</TD><TD class=tabletext style="BORDER-TOP: #24569d 4px double; BORDER-BOTTOM: #24569d 4px double" align=middle>Year</TD><TD class=tabletext style="BORDER-TOP: #24569d 4px double; BORDER-BOTTOM: #24569d 4px double" noWrap align=right>MSRP Price</TD><TD class=tabletext style="BORDER-TOP: #24569d 4px double; BORDER-BOTTOM: #24569d 4px double" noWrap align=right>Core Price</TD><TD class=tabletext style="BORDER-TOP: #24569d 4px double; BORDER-BOTTOM: #24569d 4px double" noWrap align=right>Your Price</TD></TR><TR><TD class=tabletext style="BORDER-TOP: #24569d 4px double" vAlign=top>Tinted
</TD><TD class=tabletext style="BORDER-TOP: #24569d 4px double" vAlign=top noWrap align=middle>03-05 </TD><TD class=tabletext style="BORDER-TOP: #24569d 4px double" vAlign=top align=right>$893.18</TD><TD class=tabletext style="BORDER-TOP: #24569d 4px double" vAlign=top align=right> </TD><TD class=tabletext style="BORDER-TOP: #24569d 4px double" vAlign=top align=right>$664.53 </TD></TR><TR><TD class=tabletext style="BORDER-BOTTOM: #24569d 4px double" colSpan=5><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=tabletext></TD><TD class=tabletext noWrap> </TD><TD class=tabletext noWrap align=right> </TD></TR></TBODY></TABLE></TD></TR><TR><TD class=tabletext style="BORDER-TOP: #24569d 4px double" vAlign=top>Privacy
</TD><TD class=tabletext style="BORDER-TOP: #24569d 4px double" vAlign=top noWrap align=middle>00-05 </TD><TD class=tabletext style="BORDER-TOP: #24569d 4px double" vAlign=top align=right>$691.35</TD><TD class=tabletext style="BORDER-TOP: #24569d 4px double" vAlign=top align=right> </TD><TD class=tabletext style="BORDER-TOP: #24569d 4px double" vAlign=top align=right>$514.36 </TD></TR><TR><TD class=tabletext style="BORDER-BOTTOM: #24569d 4px double" colSpan=5><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=tabletext></TD><TD class=tabletext noWrap> </TD><TD class=tabletext noWrap align=right> </TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
Old 06-07-2009, 10:06 PM
EXv10's Avatar
EXv10
EXv10 is offline
$664 ? I would definately hit the wrecking yards or get out the ol' glue.
Old 06-08-2009, 02:03 AM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
AH! i new it! i wasnt the only one!
i had my pass side window fallout a month ago, all it all replacment glass was $1600 all said and done. i replaced the vent window with the fixed style window to keep this from happening again. if it happends to the drivers side i'll do the same.
heres my post when it happend to me.
https://www.ford-trucks.com/forums/8...-fell-out.html
BTW i attempted re-mounting the window, its not really possible to do and be sure it will hold. the window comes from ford with the mounts installed.
Old 06-08-2009, 03:01 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
These threads make thankful I got fixed windows this time around.
Old 06-08-2009, 08:49 AM
vettdvr's Avatar
vettdvr
vettdvr is offline
Fellas,
Thanks!
Scott
Call the ins co. Insurance should cover it. Window broke, don't know why happens all the time. Sun,, BB's, rock
Quick Reply: Excursion Rear Glass Fell Out - How to Reattach?
