location of idle air control valve - Ford Truck Enthusiasts Forums
Old 06-07-2009, 02:28 PM
manuel78 manuel78 is offline
manuel78 is starting off with a positive reputation.
Question location of idle air control valve
can anyone help me out on the location of the idle air control valve by telling me where its at or a picture location, thanks for the help...
Old 06-07-2009, 02:44 PM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
5.4 or 4.6 or 4.2?
on 5.4 it's part of the throttle body...not sure on the other motors
Old 06-07-2009, 02:45 PM
4.6. i looked everywhere but cant find it
Old 06-07-2009, 04:29 PM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Here is what it looks like
The last two pics are from the 4.6 mustang. From; Ford Mustang IAC IAB - Solving your idle problems
Old 06-07-2009, 07:15 PM
Tylus's Avatar
normal 2v 4.6 is slightly different from that 4v Cobra motor you posted Shorebird
did that part carry over to the F-150 from the Mustangs? or did Ford re-design the wheel like they usually do
edit: wait, is that a 96 era Cobra?
Old 06-07-2009, 07:23 PM
Ford Fx4's Avatar
Ford Fx4 Ford Fx4 is offline
Ford Fx4 has a good reputation on FTE.Ford Fx4 has a good reputation on FTE.
Not sure where it's on the 4.6's but on my 02 5.4 I knew all to well where it was and it was a major PITA to get to.
Old 06-08-2009, 07:14 AM
shorebird's Avatar
Yes Tylus. however the IAC will be on the throttle body in the air path between the MAF and the manifold.
Old 06-08-2009, 09:26 AM
aric1979 aric1979 is offline
aric1979 is starting off with a positive reputation.
None of the 04-08 truck have an IAC they are all fly by wire So the throttle body does it all. It doesent matter 4.6 5.4 or 4.2 all fly by wire.
Old 08-17-2012, 11:28 PM
Carlos3838 Carlos3838 is offline
Carlos3838 is starting off with a positive reputation.
Where can I buy the throttle body for 2006 f150 4.6 CHeap??
Old 08-17-2012, 11:29 PM
Can I just clean it up??
Old 08-18-2012, 07:29 AM
elrodalonzo elrodalonzo is offline
elrodalonzo is starting off with a positive reputation.
You can try cleaning it good if that doesn't work check out the local junkyard for a used one.
occasional hart to start when hot Domino Expedition & Navigator 6 03-21-2016 10:45 AM
2001 ford escape 2.0 4cylinder Idle Air Control Valve Location??? guitarmusiczone Escape & Escape Hybrid 0 05-21-2014 05:02 PM
No Heat vietnamvet Expedition & Navigator 1 12-03-2012 02:20 PM
Throttle Body and Idle Air Control Valve malib Escape & Escape Hybrid 5 06-24-2010 09:40 PM
heater control valve orden09 Ranger & B-Series 2 02-14-2010 10:37 PM
Tags
2001, 2003, 46, 54, 54l, air, control, expedition, f150, ford, iac, idle, location, mustang, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
