Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 12-24-1999, 11:49 AM
StrangeRanger StrangeRanger is offline
Garage is empty, add now
StrangeRanger is starting off with a positive reputation.
Pre-Lightning H/P Truck?
__________________
1996 F150 XLT 2WD 4.9 E4OD.
  #2 (permalink)
Old 01-18-2000, 07:47 PM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a good reputation on FTE.82F100SWB has a good reputation on FTE.
I just picked up a second 82 F100 SWB Stepside which is equipped the same as my other one(300, SROD and 3.08's) but, it is not your average F100, it came with 235/60R15's on 8" wide rims(unfortunatley seperated from the truck somewhere along the way), while my other one came with 215/75R15's on 5.5" wide rims, and it has a l/s in it's 9".
Anyone have any idea why this truck would have been equipped this way?
Evan MacDonald
__________________
96 F350 Crew Psd/5 speed,/4x4... $600 special
96 F250 XLT PSD/5 speed/4x4... Freebie!
92 W250 LE, 4x4/CTD/G360/D60/D70U
86 F250 HD 4x4, 6.9/T19/broken D44 TTB junk/10.25.
8? F100 4x4 Mild 460/T19 D60/welded 10.25/44 Boggers,
It's not what you BUY, It's what you BUILD
  #3 (permalink)
Old 01-19-2000, 08:45 AM
Phillip Guidry Phillip Guidry is offline
Phillip Guidry is starting off with a positive reputation.
On this truck,does it have the smaller bolt pattern wheels that were offered in late 80,81 and early 82? How about the paint and trim scheme ? I saw your first post and was amazed at the speeds you accomplished in the lower gears which tells me this is a highway truck, not a hauling truck. Does SROD mean Standard Ratio Over Drive ? And does the shifter go through the very top,in the middle of the main case? Just curious !
Phillip
__________________
Phillip Guidry
Southern,LA
98 F150 2wd 3dr 4.6l Auto 80k
88 F150 2wd LWB 4.9l 4-spd Granny 195k (sold
98 FXDL
83 VT750C
08 Fusion V-6
  #4 (permalink)
Old 01-19-2000, 02:17 PM
82F100SWB's Avatar
It has the small bolt pattern(5 on 4˝?). The paint is solid black(no trim at all) with a red dash(Work truck type, nothing special at all) a vnyl seat, floor mat, the only fancy thing is the woodgrained shift ****(same as my other truck.)SROD stands for Single Rail Over Drive(all the gears are on one rail,) and the shifter is on the tailshaft, with a single rod going ahead to shift the sideloader(they're found in older Mustangs.)
Evan MacDonald
__________________
  #5 (permalink)
Old 01-19-2000, 02:59 PM
cricket cricket is offline
cricket is starting off with a positive reputation.
Evan, I'd be very surprised if Ford ever offered
8" wheels on the F100. From what I can tell the largest wheel from the factory was 6". I think someone added aftermarket wheels and tires just to
dress it up a bit. The reat gears that came out of my stepside were 247s! Now thats what you call highway gears.
Ken
  #6 (permalink)
Old 01-20-2000, 01:30 PM
82F100SWB's Avatar
Well, someone must have changed the door tag sometime in the life of the truck then. It currently has a set of 7" aftermarket white spoke wheels with 235/75R15's, which are going to be spares for my other 82, as the frame is toast on this truck,cleaned it up with my high pressure sprayer, and blew half of it away, good thing the body and drivetrain are good, I paid $1000 for the truck.
Ouch, them 2.45's must have made the truck hard on clutches, bolth of mine require quite a bit of slippage to get going.
Evan MacDonnald
__________________
  #7 (permalink)
Old 01-20-2000, 02:10 PM
Evan,
What is the information on the door tag, maybe I can have it checked by one of our Ford
techs.
  #8 (permalink)
Old 01-21-2000, 07:19 AM
82F100SWB's Avatar
It says something like rim size 8x15 and tire size 235/60R15, while my other 82 has rim size 5.5x15 with 215/75R15 listed, under the rear axle coding, it lists the axle as 134 on bolth(l/s must be added) and I think the transmission is listed as 04, I'd go out and check, but there is a rather large snow storm (4" of snow in the last hour.)
Evan MacDonald
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
