1996 Automatic Transmission vibrations (E40D?) - Ford Truck Enthusiasts Forums
Old 03-31-2002, 11:04 PM
1996 Ohio F150 1996 Ohio F150 is offline
1996 Ohio F150 is starting off with a positive reputation.
Post 1996 Automatic Transmission vibrations (E40D?)
I have a 1996 Ford F150 S/C 4x4, 5.0L with an automatic transmission (approx. 128,500 miles). I have developed an intermittant vibration that seems to happen most often at 1000 to 1500 rpm (the speed can vary). Shakes the entire truck, almost like driving on highway rumble strips. Doesn't do it all the time. Had a transmission shop flush the system, change the filter and fluid. They told me it was about the cleanest tansmission pan they had seen in some time, but that "it shifted a little soft." I do get the check engine light on occasion, but it doesn't coincide with the vibrations. Any ideas?
Old 04-01-2002, 09:29 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
First idea is to find out what code is being set. Since your check engine light is on at times there will be a code stored in memory. The problem that is setting the check engine light might be the cause of the vibrations, too.
Mark
Old 04-01-2002, 07:27 PM
Lightning2Fast Lightning2Fast is offline
Lightning2Fast is starting off with a positive reputation.
your torque convertor clutch is slipping. very common on the e4od. now i was gonna tell you to service the trans and drain the convertor but you already did this. so now there is no way around the problem but torque convertor replacment. its about 4hrs labor and the part is probably around 600$. if you pay attention it probably happens most commonly on a slight incline. this is when the convertor lokcs up. theres an easy way to be sure if its the convertor or not. just drive the truck. when it starts to vibrate step on the brake pedal very lightly. if the vibration goes away then its definitely the convertor. the brake switch unlocks the conveertor clutch. and the e4od normally shifts slushy. theve always been this way.
Old 04-02-2002, 10:44 PM
kspilkinton's Avatar
kspilkinton kspilkinton is offline
kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.
Help with my ongoing vibration issue. Jeff396 1994.5 - 1997 7.3L Power Stroke Diesel 12 07-22-2012 10:20 PM
Engine / torque convertor vibration grace553 1961 - 1966 F-100 & Larger F-Series Trucks 4 02-27-2008 08:31 AM
Transmission Flush to Cure Vibration KTim 2004 - 2008 F150 7 09-05-2007 02:55 PM
Mysterious vibration DonMurray Ranger & B-Series 8 05-09-2005 06:09 PM
F150 Vibration Problem eparra 1997 - 2003 F150 4 10-17-2001 10:59 PM
Tags
1500, 1996, 4x4, 96, automatic, bronco, case, e40d, f150, ford, rpm, transfer, transmision, transmission, troubleshootingvibration, truck, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
