wrecked 4X4 F150 Build Thread
#48
i have no idea what the name of the paint is... its extra from one of my bros projects.
my dad did a lot of work wile i was gone... i ran some wires for my amp and my dad put the carpet in. not sure if im running subs yet or not
my dad made kinda ghetto speaker bracket for the rear but it works
back window and headliner in
#49
LONG OVER DUE UPDATE!!
soooo since my fuel tanks were nasty i bought new front and rear tanks. i also stupidly bought a 33 gallon bronco rear tank that has been an absolute PIMA!! i got about $80 in fuel pump assemblies at the pick and pull. im so glad im done messing with pumps
Decided that i wanted to sandblast use chassis saver on my frame and under the body... it turned out very good
The Frame Paint
Front Tank In
And the bronco tank hitting the bed!
I used old straps out of a really old box truck thats rotting at my dads shop
cut the beam accross the bed to clear the rear fuel tank
also bought a super cheap keyless entry/remote start
Blasted my steel 12 wides and bought some 15x12 weld scorpios
Rims sitting on the truck, after i fixed the broken hard brake line and added my longer rubber brake lines
much bodywork ahead
The Frame Paint
Front Tank In
much bodywork ahead
#54
#55
plus i still have to put the lift on
im ready to drive this thing!
#56
#58
#59
I completely agree
Have you ever tried mounting 13.50 tires on a 12" rim? You've got to stretch the sidewalls quite a bit to even catch the bead mounting surface. I can pretty well guarantee that you're not going to like the look, unless you want your sidewalls stretched wider than the tread pattern. The smallest tires I've ever seen that fit on a 12" rim, and looked right, were 38x15.50 Swamper Boggers, and getting them to seat the bead was no picnic.
EDIT: Other than the rim selection, I have to say awesome build! I likes it
#60
I completely agree
thanks but you dont know what your talking about. plunty of people have done this and it would only look ugly is if i got a completely non aggressive tire mounted on a 12 wide.
this is an F150 with 6 in lift on 33x13.50x15 TSL's on 14 wides
