it may not be a chevy, but the transmissions are all the same, with exception of bellhousing pattern (top two bolts different), but dual patterns are available, motor mount locations are the same, 5.7 diesel diesels were olds motors, and all 330-455 series motors use same mounts(except for height), and not only do i have access to a flywheel, but the aftermarket is gaining support. thank you for the tip on using the chevy tranny. i am however hoping to use the orig 4 speed for shifter location (and its still in good condition, lol). unfortunately, i have access to all the parts i could want, except a respectfull FE motor. gobs of 352's and 360's, but i wont downgrade(sorry guys). thanks for the replies, and hopefully someone will have info of a swap that they know of personally!
