just bought a propane truck, it sputters when on the highway...
02-10-2009, 11:10 AM
hey guys, i recently bought this truck to just haul stuff around it, it runs on propane, it sarts and drives fine, but when you give it more than 1/2 throttle or take it past 50mph it starts sputtering. the prev. owner told me its some filter that needs to be changed... i've never dealt with propane do i dont even know where to start.... What should i check and replace?
02-16-2009, 01:26 AM
on
What year? engine, trans, brand of the system?
07-27-2009, 12:47 PM
on
follow the fuel line from the tank to fuel lock device
remove screws (carefully sometime soft and stripe easily)
filter is white material
cost $8 buck in canada
takes about 10 minutes.
07-27-2009, 12:48 PM
i ended up doing that, replaced the filter, the truck was ok for about a day, then started sputtering again... i ended up getting rid of it for more than i paid for it and didnt bother with trying to fix it
07-29-2009, 01:18 PM
on
FYI: i suspect rust in the tank, a problem with early tanks
08-08-2009, 02:59 PM
on
kind of pointless now but i would have guessed a partially plugged vapor line. what temp thermostat was it running?
PaulsEdge
Alternative Fuels, Hybrids & Mileage
01-09-2017 07:09 AM
RickW2007
10-29-2016 11:54 PM
deisele75
18
07-02-2016 06:12 AM
amdriven2liv
Fifth Wheel & Gooseneck RV Towing
12-18-2015 07:36 PM
Chevman
11-01-2006 06:05 PM
351m,
460,
company,
engine,
f150,
f250,
ford,
highway,
motor,
motors,
propane,
runs,
sputters,
throttle,
truck
