Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-06-2009, 05:55 AM
elgato54 elgato54 is offline
2004 Ford Ranger
elgato54 is starting off with a positive reputation.
Another P0171 and P0174 Nightmare
2004 Ranger Edge 3.0, Auto, 36,000 miles. Everything stock.
Truck throws P0171 and P0174 codes as soon as it runs a few minutes.
(Lean both banks) It does take a lot longer to throw the codes when using a K&N type filter instead of stock.
It runs great, idles fine and gets 17-19 MPG around town.
New air filter.
New fuel filter. (65 PSI)
Cleaned MAF and tried a different one.
No obvious vacuum leaks. (Propane test)
This truck does not have an EGR or DPFE.
Not sure if its related but the problem seemed to start after replacing the gas cap to fix the gas cap light.
Took it to the mechanic today. He could find no vacuum leaks but replaced the upper intake seals. Same problem.
He was extremely frustrated and said maybe the dealer can find something.
Any help or suggestions would be appreciated. It looks like I am falling into the same trap as almost everyone else with these codes.
The Ford dealer wants $150 flat rate to diagnose the problem. He said it is usually the lower intake gaskets. It would be sad to see this on a 36,000 mile truck.
What are the odds a smoke test would find anything?
Thank You
  #2 (permalink)
Old 06-06-2009, 08:14 AM
MikeB 88's Avatar
MikeB 88 MikeB 88 is offline
2000 Ford Ranger
MikeB 88 is starting off with a positive reputation.
Our Sable threw the P0171 and P0174 codes. Wound up the hose off the PCV was crushed and split. This link should take you to a picture of it.
Board Message
__________________
Mike B
1997 F-150 XLT Extended Cab Flareside (son's truck)
1969 ForDor Thunderbird
2001 Mercury Sable
2006 Dodge Charger (wifes car)
2000 Ranger Regular cab
  #3 (permalink)
Old 06-06-2009, 10:14 AM
carsrus carsrus is offline
carsrus is starting off with a positive reputation.
Check to see if your coolant reservoir is going down, even slightly. If it is it sounds like the lower intake gaskets are done. My dads ranger blew them out basically at 150k and it was pissing coolant all over the place.
  #4 (permalink)
Old 06-06-2009, 10:23 AM
tomw tomw is offline
tomw is gaining momentum as a positive member of FTE.
carsrus: Did the leak take out the catalytic converter? Or was it an external leak... My old ride uses coolant a little, and I found a bit on top of the timing chain cover when it sat for a few weeks.
You could 'possibly' get a lean code if the engine is missing badly enough to leave unburned fuel/air in the exhaust. O2 is O2, and the sensor does not know the reason why.
Did you clean the injectors? Does it idle smoothly? Any burps or chugs accelerating or at cruise?
The symptom of the lean codes is drawn from the O2 sensor reporting a low voltage situation. The O2 generates voltage based upon the % of O2 in the gas passing by the sensor, after it has reached its operating temperature. My memory shaker is the phrase 'low is lean'. So, if the O2 sensors were dysfunctional, they would be reporting a lean condition. Have you tested the O2's? Are they old and poisoned? Did you ever feed them anti-freeze? Or RTV sealant or carb cleaner? Any of those can foul the O2 so they quit working. Then they report lean all the time... as they produce no voltage.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #5 (permalink)
Old 06-06-2009, 01:27 PM
g_k50's Avatar
g_k50 g_k50 is offline
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
P0171 and P0174 both point to Fuel Control.
Possible causes
Fuel system
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction system including Air leaks after the MAF, Vacuum leaks, PCV system, Improperly seated engine oil dipstick.
EGR system including Leaking gasket, Stuck EGR valve, Leaking diaphragm or EVR
Base engine including Oil overfill, Cam timing, Cylinder compression, Exhaust leaks befor or near the HO2S's
  #6 (permalink)
Old 06-06-2009, 01:30 PM
g_k50's Avatar
1990 Ford Bronco
My Garage
If you can check the value for SHRTFT-1 SHRTFT-2 should be between -25% to 35%
and LONGFT-1 LONGFT-2 between -35% to 35%. Readings beyond these values indicate a failure.
  #7 (permalink)
Old 06-06-2009, 01:36 PM
g_k50's Avatar
1990 Ford Bronco
My Garage
It is necessary to address all Continuous Memory Ignition and Misfire DTC's if received during Continuous Memory testing, before addressing any Fuel Trim DTC's, which is P0171 and P0174.
Check intake air system for leaks, obstructions and damage
Check air cleaner element, air cleaner housing for blockage
Verify integrity of the PCV system
Check fuel delivery system and filter ofr restriction
Check for vacuum leaks.
Repair as necessary and reset KAM,
  #8 (permalink)
Old 06-06-2009, 05:08 PM
g_k50, what about the DPFE failure at ~60k miles? We have a 1997 3.8 Bird with 65k that just threw p0171 & p0174. It runs fine, no miss, no knock, no shaky idle, just turned on the CEL while pulling out of a shopping center. I had read that the DPFE can get corroded and mis-report the amount of EGR that is being flowed, thus misdirecting the ECM to enrich the fuel mixture.
PCV is OK, and power level seems fine. I just changed the air filter, and have hopes that will effect a cure... It was rather dirty, thus limiting air flow. How would that cause a lean report?
tom
__________________
  #9 (permalink)
Old 06-06-2009, 10:08 PM
g_k50's Avatar
1990 Ford Bronco
My Garage
How are you getting the P0171 and P0174 codes? Any others? Any Check Engine Light?
The Manual I'm using goes to the MAF next.
  #10 (permalink)
Old 06-06-2009, 10:12 PM
g_k50's Avatar
1990 Ford Bronco
My Garage
tom
I have a 2001 Emissions manual. I'm not sure how applicable it would be to a 1997. My 2001 Ranger 4.0L had a CEL that turned out to be the DFPE, I took it to the Dealer and he replaced it under warrenty because it was under 50,000 mi. But I did end up spending 500 on a tune up and brake work.
  #11 (permalink)
Old 06-07-2009, 10:29 AM
The CEL came on, and my wife took it to a parts place that would pull the codes. Maybe this will be my excuse to get an OBD-II reader.
I have the 97 shop manual on CD, but hadn't thought to look at the emissions stuff. Duh.
tom
__________________
  #12 (permalink)
Old 06-27-2009, 10:00 AM
kaboom10's Avatar
kaboom10 kaboom10 is offline
2002 Ford F-150
kaboom10 is starting off with a positive reputation.
I'm getting a zero reading from my bank 1 rear O2 and a P0174 code. Could this be the culprit?
__________________
2002 F-150 5.4L 4wd
Baer rotors EGR Carbon Kevlar pads-Kenwood stereo-IAS shocks
Livewire PRP tuned w/wideband O2-4.88 gears and Trutrac carrier-B.F.Goodrich Rugged Trail
http://i48.photobucket.com/albums/f2...0/100_0291.jpg
  #13 (permalink)
Old 06-27-2009, 07:48 PM
Quote:
If your getting lean for only one bank and its running fine, chances are its the o2 sensor.
  #14 (permalink)
Old 06-27-2009, 08:01 PM
kaboom10's Avatar
2002 Ford F-150
Quote:
Sounds logical to me.
  #15 (permalink)
Old 06-27-2009, 09:02 PM
WA4OSS WA4OSS is offline
WA4OSS is starting off with a positive reputation.
After three months of this, I went to a Ford dealer and the pcm was reflashed with a firmware upgrade. 12,000 miles later no re-occurrance.
2003 3.0 Liter V6 Auto Cabplus.
Tags
2000 , ford , p0171 , p0174 , ranger , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
