Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 06-28-2009, 09:45 AM
tomw tomw is offline
tomw is gaining momentum as a positive member of FTE.
I have a DPFE on the shelf right now, but am holding off until I can see if the CEL comes back on. I did replace the air filter, and that was among the first things to look for in the diagnostic tree.
Is it a fact that disconnecting the battery for 5 minutes will erase the KAM? Per the CD shop manual, doing that will erase the KAM and turn off the CEL. If the filter fixes the problem, it will not turn back on.... Or so I hope.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #17 (permalink)
Old 07-01-2009, 05:10 AM
elgato54 elgato54 is offline
2004 Ford Ranger
elgato54 is starting off with a positive reputation.
Quote:
Originally Posted by WA4OSS View Post
After three months of this, I went to a Ford dealer and the pcm was reflashed with a firmware upgrade. 12,000 miles later no re-occurrance.
2003 3.0 Liter V6 Auto Cabplus.
Was there a TSB for this specific problem or did they just routinely update it?
THanks
  #18 (permalink)
Old 07-01-2009, 06:28 AM
WA4OSS WA4OSS is offline
WA4OSS is starting off with a positive reputation.
The technician was informed of symptoms and previous attempts to solve same. I told him another tech had said to get the pcm re-flashed. He brought the vehicle back to me and said ther had been two updates since the truck was purchased. He did them and said he thought this would solve the problem. It did. Cost was $86.00 if I remember correctly. Good luck.
  #19 (permalink)
Old 07-01-2009, 10:13 AM
g_k50's Avatar
g_k50 g_k50 is offline
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
I think the Ford warrenty is good for 50,000 miles on emissions releated problems, the CEL is a emissions related problem, take it to Ford and have them fix it under warrenty.
  #20 (permalink)
Old 07-01-2009, 01:58 PM
Federal or California emissions are supposed to be covered by an 8/80,000 warranty from what I heard. Upped from the original 5/50,000 several years ago. FWIW.
Pull out the emissions warranty pamphlet, or check with EPA.gov
tom
__________________
  #21 (permalink)
Old 07-02-2009, 03:21 AM
2004 Ford Ranger
tom
It looks like the only things covered by the 8/80 are the Cats and the PCM.
So, even though the dealer is charging you $150.00 for diagnostics and has the scanner connected they want an additional $110.00 to flash the PCM. One guy owns all the Ford dealers here so there is no incentive for competition.
  #22 (permalink)
Old 07-04-2009, 09:50 AM
Go to a Lincoln Mercury dealer... They can do re-flashes too. Or does he own them too?
You said:
"Not sure if its related but the problem seemed to start after replacing the gas cap to fix the gas cap light."
Is it possible you installed a gas cap with the wrong check valve? It could be that the pump is trying to pull fuel and the cap is not allowing air to enter to replace the volume of fuel pumped out. I did not know that there was a specific 'gas cap light'...
tom
__________________
Tags
2000 , ford , p0171 , p0174 , ranger , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
