Urgently require rear leaf springs
Hi
I hope someone can help, I live in the UK and love driving my F150, I am trying to locate the following part YL3Z5560CA (rear leaf spring), but having no luck I am being advised by the various people I have contacted in the UK & the US that this part is now obsolete.
My Vehicle Model: 2001 Ford F150 Harley Davidson
Vin no: 1FTRW07L01KA31079
Part no required: YL3Z5560CA
Description: Rear leaf spring
Quantity required: 2 (1 for each side)
I would greatly appreciate anyones help in locating this part, who would have thought it would be this difficult to locate a part for such an iconic vehicle.
Kind Regards
Richard
Kind Regards
Richard
Thats weird. Well maybe try Direct Ford Parts then. If that doesn't work check out Bronco Graveyard. They have F Series parts so its worth a shot. You could also check with NPD and LMC. You could also ask the Lightning guys on NLOC.
Silver State Ford Parts Genuine Ford Truck Parts Lincoln Mercury Parts OEM Ford Parts and Accessories
How did you break or damage the spring?
you could look into a drop leaf? lower the stance 3" and save some cash.
Lowering Leaf Springs by Belltech and other Lowering Parts available at StylinTrucks.com
you could buy replacement rear leaf springs from virtually any truck spring shop. It does not necessarily have to be an oem part. Why dont you contact a truck spring shop in your country? New ones here are a couple hundred a side aftermarket. It goes by length, axle center mounting pin location and spring rates, very simple.
However you could try stengelbros.com I bet they can supply.
chucky2
11-23-2016 09:27 AM
Alongcamelee
07-15-2016 01:33 PM
