Red Head Steering gear box installed - Page 8 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #106
Old 03-08-2011, 05:58 AM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
Well, I found a better (and cheaper) way to go than the ORU kit. The ORU kit attaches to the front differential cover with the supplied bracket. I have already purchased the Mag-Hytec front differential cover but it needed to be modified for the bracket. ORU offered to exchange my stock Mag-Hytec cover for their modified Mag-Hytec cover, which was nice of them. However, the cost of the kit is still expensive at close to $1,200.00 after the core charge.
PSC Motorsports make a kit for the Super Duty that sells for $507.07. This kit does not attach to the front differential so I can use my stock Mag-Hytec differential cover. For the $507.07 price, PSC Motorsports will modify (port) your steering box. In short, I can get a quality kit for less than 1/2 of what the ORU kit costs.
06-08 Ford Truck Cylinder Assist Kit-SKR500 : Cylinder Assist Steering System Kits, Ford Cylinder Assist Steering Systems | PSC Motorsports - performance steering components
However, I'm thinking of having Red Head Steering rebuild my steering box then having PSC Motorsports modify (port) it for their kit or visa versa.
  #107
Old 03-08-2011, 09:06 AM
Monster-4's Avatar
Monster-4 Monster-4 is offline
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
That looks nice. Wish they made one for the 99-04 trucks.
  #108
Old 03-25-2011, 02:41 PM
XFRBILL's Avatar
XFRBILL XFRBILL is offline
XFRBILL is starting off with a positive reputation.
is anyone replaceing the steering box with the red-head box because they are getting the front end wobble as well? and if so has that helped the issue?
  #109
Old 03-25-2011, 03:54 PM
bill11012's Avatar
bill11012 bill11012 is offline
Modular motor junkie
bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.
It helped my wobble alot. Then I added a moog steering stabilizer and it fixed it for good.
  #110
Old 03-26-2011, 12:55 PM
XFRBILL's Avatar
Quote:
I have a fabtech lift with dual stabilizers and the wc motorsports track bar. the bar helped but then it recently started again. drag link needs replacing even though it was done last summer. there is alot of play in steering box now. it wanders all over the place. trying to see what my best option is
  #111
Old 03-26-2011, 01:30 PM
bill11012's Avatar
If the box is loose I would start there. Front tires are the other thing. Mine seems really sensitive to an off balance front tire.
  #112
Old 04-22-2011, 08:47 PM
shwitey shwitey is offline
shwitey is starting off with a positive reputation.
Received my redhead yesterday and got 'er in today. The write-up at the begining of this thread helped tremendously. I had the laptop on the bench I'm new to the super-dutys so I was starting from scratch ie. had to figure out air box removal...
The steering is now tight as ever and the truckis much more enjoyable to drive.
I'll throw in a little from my experiance today:
One should be prepared to replace the bolts which hold the steering box to frame, mine were super corroded and were hard winding out/ in, I'll replace with proper bolts sooner than later.
The pitman arm is on real good. A puller is a must. I tried rigging up in my shop press and no luck...even at 5 tons on the gage. I borrowed a puller, cranked the h*ll out of it with my breaker bar. Remove breaker bar and hit the the puller screw with a bfh. It finally let go....since today is a holiday and nothings open, i was very pleased to say the leased.
Again, 1000 thank-yous for the write-up! If i knew how to give reps, i would!
Dave
  #113
Old 04-22-2011, 10:19 PM
Monster-4's Avatar
Thanks and glad to hear the install went smooth!
  #114
Old 05-26-2011, 01:50 PM
Monster-4's Avatar
A small update. The Red Head is still doing great but I had a pretty significant memory steer issue. This weekend I removed the tie rod from each knuckle and I found out the drivers side was stiff. I replaced the ball joints 23K miles and 3 1/2 years ago but the upper ball joint was bad. It was either defective to begin with or went bad sometime soon after installation. Below is a (crappy) video I took. I replaced the lower ball joint as well since I damaged it getting it out to replaced the upper one.
I only drove the truck about 20 miles since doing this but it drivers considerably better and easier. I didn't notice before how much effort to took to turn the wheel.
<iframe width="425" height="349" src="http://www.youtube.com/embed/p1SCFDpD-EA" frameborder="0" allowfullscreen></iframe>
  #115
Old 05-27-2011, 10:35 AM
Mercury45 Mercury45 is offline
Mercury45 is starting off with a positive reputation.
ALL.... I read this thread and have recently ordered a new red head steering gear and new PS pump, starting to replace all of this later on this afternoon. I already loosened the track bar bolts (i have new bushings for that) and cracked loose the mounting bolts for the old steering gear, I also cracked the flare nuts loose as well. I have new high pressure lines as my old were leaking. My original problem was the steering was acting funny, it ends up that it was just a low fluid situation I think. The wheel would not return to center and do all sorts of funky stuff.
I know with the read head this will feel much better. I am a little scared as this is the first time I ever done anything with steering.
I replaced tie rods and drag link about a month ago, so thats nice new stuff....
My question is do you all remove the pitman arm AFTER the box is off the truck, to do it on the truck would require removing the track bar bracket and i sort of did not want to do that.
Red head explained they sent the box being pre-centered all i have to do is mount it. I just need to make sure I get the pitman arm on there right and then the other end of the box needs to go to the wheel in the right spot. I do not want to mis-align anything.
For being the first time doing this I am keeping the article written close at hand, along with the ford manuals... but is there any tips and tricks I should know about?
I have a 2003 F250 4x4 with 37" tires and 6" superlift.
thanks, Kenny
  #116
Old 05-27-2011, 11:34 AM
Monster-4's Avatar
Yes remove the steering box first and then remove the pitman arm. It's really the only way unless, like you said, you want to remove the track bar. Even doing that the pitman arm is on there pretty tightly. I had mine mounted by the pitman arm in a vise and cranked down on the puller with an air wrench and it still took a few blows with hammer to get it to pop off. I wouldn't want to manage this while the steering box was still mounted on the truck.
I unfortunately didn't get any pics of this process. As you can tell I took the pics after the work was done. Since it was just me I didn't want to risk getting the camera dirty and my hands were covered with dirt, grease, fluid, etc.
A few tips. Make sure you wind the seat belt through the steering wheel. This will make sure it stays centered and you don't run the risk of damaging the clock springs in the steering wheel.
Another tip is inspect closely the rubber donut that is at the end of the steering shaft. Make sure it's not brittle or torn. If it is replace the lower steering shaft.
One final tip is when getting the steering shaft back on to the input shaft of the steering box be prepared to battle with it a bit. It took be a little bit to get it back on and was properly the only time I got frustrated. In the pic I have an arrow to the part I found the best to tap with a hammer to get it back on.
Hope this helps and don't be worried. It's pretty easy job. If you have any more questions post back or when you get the job done.
  #117
Old 05-27-2011, 03:14 PM
Pinky Demon's Avatar
Pinky Demon Pinky Demon is offline
Pinky Demon is gaining momentum as a positive member of FTE.Pinky Demon is gaining momentum as a positive member of FTE.
Mines still tight and lovely!
  #118
Old 05-27-2011, 05:22 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Mine's been super tight since '00......................guess I got lucky (150k miles)
  #119
Old 05-27-2011, 09:40 PM
Monster-4's Avatar
Yep guess you did.
  #120
Old 05-28-2011, 05:44 AM
status
Hi all.... monster 4x4 thanks for the info.... the rubber thing you are talking about is that at the end of the shaft that allows the smaller (lower shaft) to slide into it towards the steering column, those parts all seem ok, but ill take another look.
WHAT A PITA the steering pump pulley was, they say to pull it off and re-use it - uh yeah right, i bent the living snot out of it just getting it off, heat and penetrating oil, and finally i got it. Then last night the only place that had a pully was an hour away, i am about to get back in there and finish up today.
Also.... the pitman arm, wholly smokes thats on there.... Every puller i bought did not fit over the pitman arm so i had to bring it to a shop and get it pressed off.... SOB i should have bought a new pitman arm haha.well maybe not they are like 100 bux.
So i mounted the new pitman arm with the air gun, then torqued it to 210 ft lbs, they ask for 199
I am afraid that I do not have everything perfectly centered i know the pitman arm is on the shaft right, (it only allowes you to mount it in 90 degree ways) but the box to the steering shaft is where i might get it alittle off, any way to make sure i got that right?
Anyway, back to work i go, trying to get this all done i have to cut trees!
thank yiu
kenny
steering gear box removal beartracks Brakes, Steering, Suspension, Tires, & Wheels 0 02-29-2016 12:58 PM
Steering shaft tear down and insp 77&79F250 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-16-2016 09:18 PM
just installed Red Head steering gear box .. NICE TNT in Round Rock 1999 to 2016 Super Duty 2 02-08-2012 09:28 AM
Red Head Steering Box Install Problem yank50 1999 to 2016 Super Duty 6 12-05-2011 10:06 PM
Red Head Steering VS. A1-Cardone AbandonedBronco 1978 - 1996 Big Bronco 3 03-23-2011 04:49 AM
Tags
box, duty, ford, gear, gear box, head, how to, install, installing, red, red head steering, redhead, remove, replace, steering, steering box, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
