Red Head Steering gear box installed
You're welcome. I was actually going to update this thread with my latest mod. I installed a filter on the return line. Can't say it was my idea.
https://www.ford-trucks.com/forums/8...ing-flush.html
I just realized in step 4 that I never gave this warning:
The clock spring can be damaged if you have the steering shaft disconnected and the steering wheel is turned to much in one direction. This is why it is important to immobilize the steering wheel as much as possible to avoid turning it.
It only takes a few revolutions of the wheel for damage to happen. It's easy to do when you are wrestling with the steering shaft. Also if the steering wheel is not centered lock to lock and you put everything back together you can damage the clock spring when you turn full lock.
#30
So far it's worth every penny. Keep in mind I pretty much replaced everything else in the steering system (expect for pump) before replacing the box because there was so much slop in everything. The steering box was the biggest improvement.
You can try adjusting the steering box itself before going through the expense of replacing it. On top of the steering box is a lock nut and hex head bolt. Loosen the nut and turn the bolt 1/8 to a 1/4 turn. Tighten the lock nut back down. Go for a spin and see if that helps. You can do this adjustment a few times but you do not want to get the adjustment bolt to tight otherwise you can bind the steering box up. Also this is usually considered a band-aid for a worn out box.
Also you want check the rest of the steering system for issues. Check the drag link, tie rods and ball joints for slop and woren parts. Have the alignment checked and give you tires an inspection as well. Any of these or all these can be the root of your problem as well as the steering box.
