Red Head Steering gear box installed - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-09-2009, 07:20 AM
F35099 F35099 is offline
F35099 is starting off with a positive reputation.
Thanks for the nice writeup. My steering is starting to feel loose. May have to do this soon.
Old 06-11-2009, 03:16 PM
Monster-4's Avatar
Monster-4 Monster-4 is offline
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
So far this steering box has been worth it. My wife drove my truck for the first time since replacing it. Even she was amazed at the difference and promised not to complain about the money I spent on it anymore!
Old 06-11-2009, 06:25 PM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
If I ever get married I'm definitely buying one of those steering boxes! Just kidding...
Old 06-11-2009, 06:55 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Quote:
That would be great if that was all it took to keep them happy.
Old 06-11-2009, 07:18 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
Great write up. Can't help but wonder if a cooler would help the steering boxes last longer.
Old 06-11-2009, 09:01 PM
Monster-4's Avatar
The PS system does have a cooler (all be it little) but I don't think temps have much to do with the box going bad. According to the guys at Red Head it's just part wear and part high tolerances in manufaturing that lead to a sloppy handeling steering box after awhile.
Old 08-09-2009, 07:49 PM
Not-Fast-Enuf's Avatar
Not-Fast-Enuf Not-Fast-Enuf is offline
Not-Fast-Enuf is starting off with a positive reputation.
Thanks for the info & pics. The pitman shaft on my truck snapped a couple of day ago & this looks like the way to go.
Old 08-09-2009, 09:21 PM
Monster-4's Avatar
You're welcome. I was actually going to update this thread with my latest mod. I installed a filter on the return line. Can't say it was my idea.
http://www.ford-trucks.com/forums/82...ing-flush.html
Old 08-09-2009, 09:31 PM
Monster-4's Avatar
I just realized in step 4 that I never gave this warning:
The clock spring can be damaged if you have the steering shaft disconnected and the steering wheel is turned to much in one direction. This is why it is important to immobilize the steering wheel as much as possible to avoid turning it.
It only takes a few revolutions of the wheel for damage to happen. It's easy to do when you are wrestling with the steering shaft. Also if the steering wheel is not centered lock to lock and you put everything back together you can damage the clock spring when you turn full lock.
Old 08-20-2009, 10:05 PM
tnardo's Avatar
tnardo tnardo is offline
tnardo is starting off with a positive reputation.
any issues with turning of the steering gear while installing the pitman arm?
Old 08-20-2009, 11:28 PM
No, just get it on the right spline.
Old 08-21-2009, 12:25 AM
Pinky Demon's Avatar
Pinky Demon Pinky Demon is offline
Pinky Demon is gaining momentum as a positive member of FTE.Pinky Demon is gaining momentum as a positive member of FTE.
I'm really starting to look into this now. I always have to hold my wheel slightly to the left because it will not track straight, and overall, the steering has a lot of wander to it. Very terrible.
Now that you've had it long term, what are you thinking?
  #28
Old 08-21-2009, 02:50 AM
Who? Sounds like you have a steering problem to track down. Camber good? Wheels snug on hub?
  #29
Old 08-21-2009, 07:21 PM
Monster-4's Avatar
Quote:
No problem with that but make sure the box is centered lock to lock before you mount it in the truck. Otherwise you might not be able to turn all the way in one direction.
  #30
Old 08-21-2009, 07:43 PM
Monster-4's Avatar
Quote:
The drag link can be adjusted to recenter the steering wheel. It make take a few tries to get it just right but it's simple to do. Loosen the two bolts in the adjuster and twist it one direction or the other to center the steering wheel. Retighten the bolts and go for a spin. Rinse and repeat as needed.
So far it's worth every penny. Keep in mind I pretty much replaced everything else in the steering system (expect for pump) before replacing the box because there was so much slop in everything. The steering box was the biggest improvement.
You can try adjusting the steering box itself before going through the expense of replacing it. On top of the steering box is a lock nut and hex head bolt. Loosen the nut and turn the bolt 1/8 to a 1/4 turn. Tighten the lock nut back down. Go for a spin and see if that helps. You can do this adjustment a few times but you do not want to get the adjustment bolt to tight otherwise you can bind the steering box up. Also this is usually considered a band-aid for a worn out box.
Also you want check the rest of the steering system for issues. Check the drag link, tie rods and ball joints for slop and woren parts. Have the alignment checked and give you tires an inspection as well. Any of these or all these can be the root of your problem as well as the steering box.
Red head steering wtroger 1987 - 1996 F150 & Larger F-Series Trucks 1 10-17-2016 07:36 AM
steering gear box removal beartracks Brakes, Steering, Suspension, Tires, & Wheels 0 02-29-2016 01:58 PM
Steering shaft tear down and insp 77&79F250 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-16-2016 10:18 PM
Steering Damper 77_f250_custom 1973 - 1979 F-100 & Larger F-Series Trucks 6 04-21-2015 08:17 PM
Sloppy Steering Finally Fixed! JEDWIN 1973 - 1979 F-100 & Larger F-Series Trucks 10 04-28-2011 06:05 PM
Tags
box, duty, ford, gear, gear box, head, how to, install, installing, red, red head steering, redhead, remove, replace, steering, steering box, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
