Stumbling and running rough under load and WOT
Old 06-05-2009, 10:33 PM
boggerted's Avatar
boggerted
boggerted is offline
Im trying to diagnose why my 89 F350 5.8 is running poorly. If you drive it under 1/2 throttle and about 1500 rpms, it runs perfect, no missing or stumbling. however, if you are under a load (or somewhat lugging in a high gear) It loses all power and the motor shakes pretty bad. Unloaded, the truck actually accelerates faster at 1/2 throttle than at full throttle. I did plugs, wires, cap, and rotor and that helped, but didnt cure my problem. I pulled codes and the only codes I got were code 33 and 29. What Should I look at? Thanks and sorry for such a long post.
Old 06-05-2009, 11:48 PM
393STROKER's Avatar
393STROKER
393STROKER is offline
Check for any vacuum leaks,this would cause the engine to run lean under load.
Old 06-06-2009, 02:09 AM
NashT's Avatar
NashT
NashT is offline
Sounds to me like you may have the timing off.
Did you turn the distributor at all when you did the tune up?
And if you need me to I can look up what those codes are in my book, let me know.
And the best way to check for a vacuum leak if getting a can of brake cleaner and spraying it on vacuum lines. If any gets sucked in you will be able to tell, because it will run better momentarily.
-NashT
Old 06-06-2009, 04:15 AM
lew52's Avatar
lew52
lew52 is offline
I never heard of using brake cleaner ?? Sure its not carb cleaner ?? Lew
Old 06-06-2009, 04:26 AM
17fordguy's Avatar
17fordguy
17fordguy is offline
carb cleaner works also check fuel pressure and fuel filter
Old 10-24-2010, 08:37 PM
firewoodtrucker's Avatar
firewoodtrucker
firewoodtrucker is offline
mine is doing the same thing...did you ever get it fixed and running right...if so how...please help
Old 01-10-2011, 12:17 PM
Floor-N-It's Avatar
Floor-N-It
Floor-N-It is offline
My F350 7.5L is acting the same way. When timing it do you also disconnect the air pump control valve( the one that is connected to the Cat ) and pull the ecu plug?
Old 01-10-2011, 12:49 PM
skeith5's Avatar
skeith5
skeith5 is offline
My truck was running similiar. Here's what I did...
New distributor - didn't help the problem.
Checked the TPS - measured fine
Replaced coil - The truck seemed to start a little better, but this didn't resolve the problem.
Replaced plug wires - Got Napa wires which was a mistake. Get ford wires. The truck ran smoother after I replaced one of the napa wires which was grounding out.
Replaced plugs - The old ones were gapped incorrectly. Replace with copper core. The truck ran a bit smoother after new plugs
seafoam treatment - I'm not sure this helped too much, but I'd do it again.
check for vaccum leaks - I had one at the "tree" on top of the manifold. Engine ran a bit smoother after that was fixed.
Fixed intake leaks - I had several leaks at the upper to lower intake connection and at the lower to head connection. I stripped everything down and put on new gaskets. While I was there I cleaned out the intake which was caked in carbon and sludge
clean the TB - Mine was caked in sludge, even after the seafoam treatment. The truck ran much better after it was cleaned.
unhooked the EGR - Bingo, this was really it for my truck. The egr was malfunctioning. When the vaccum line was disconnected from it and plugged the truck runs like it should. Well like a 200k mile engine should at least.
Old 01-10-2011, 09:41 PM
firewoodtrucker
found the problem
finally.....slight kink in the fuel line.....engine is running 100 % now....just need to replace the fuel selector valve because I am losing fuel from the rear tank into the front tank
Old 01-10-2011, 10:09 PM
bbeck0314's Avatar
bbeck0314
bbeck0314 is offline
Truck is running really rough. Replaced a lot already
Truck was getting rough. Replaced plugs, wires, cap, rotor, battery, fuel filter, and starter. Ran good for a short time then started getting worse and worse. Replaced the egr valve, no change. Replaced the idle air control valve, no change. Replaced the fuel pressure regulator, checked plugs, driver side were scorched, and two wires were broke. Replaced all wires and plugs, ran fine for a day. Now chugging again after only one day. It's driving me crazy, please help. I have an 1988 f150, 2 wheel drive, with a 351 engine.
Old 01-10-2011, 11:09 PM
skeith5's Avatar
skeith5
skeith5 is offline
What kind of wires did you put in it??
Old 01-11-2011, 04:37 AM
bbeck0314's Avatar
bbeck0314
This time around I put autolite wires in. Ive also ran two cans of seafoam thru it and had walmart do a complete fuel system clean.
gstanfield
6.2L V8
58
03-02-2024 09:57 PM
illushinz
Modular V8 (4.6L, 5.4L)
10-22-2016 12:27 AM
Dialtone
1997 - 2003 F150
24
07-27-2016 08:52 AM
Lowpala
10-22-2015 08:34 PM
mattjensen
15
10-10-2011 12:00 PM
Quick Reply: Stumbling and running rough under load and WOT
