T'case swap questions
I have an NP 203 full time chain drive t'case in my 76 F-150 (360, C6), but got a NP 205 out of a Bronco which also had a C6 transmission. I'd like to swap the part-time, gear drive t'case into my truck. Other than changing the shifter (although I'm told the 203 shifter can work even though the pattern would be wrong on the ****), I'm pretty sure I'll have the change the driveshafts.
Anyone done this? Is it worth the hassle for an around-town, bad weather truck? No plans for lift or anything major (although trans leaks in front, so need to rebuild). Any and all help would be great. Thanks.
Matt
Matt
MAHinton
10-18-2003 01:01 AM
