06-09-2009, 12:54 AM
Tony, go here and you may find the info you are needing.
Techno Source for the 1932 thru 1953 Flathead Ford
If you have have some wrist pins out of the pistons, I wonder if you could measure them with a micrometer. I need the size for a project I am working on.
__________________
2002 F350 7.3 Ltr. 6sp.DRW 170K miles, 13' service body W/2200 # Venco hoist, Air compressor,10KW welder/generator, Air Horns, ceiling mtd CB W/250W Amp, Exhaust brake, Aux. Idle Control and Vac. operated hot water control.
1952 F1 flathead Project Truck
(It's got eight cylinders and I use them all )
