Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 06-05-2009, 10:29 AM
lowell75 lowell75 is offline
Garage is empty, add now
lowell75 is starting off with a positive reputation.
More power!
Anyone else note this...or try?
How to fuel a car on waste plastic - tech - 01 May 2009 - New Scientist
  #2 (permalink)
Old 06-06-2009, 11:27 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
link isn't working?
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #3 (permalink)
Old 06-06-2009, 12:17 PM
juneau76's Avatar
juneau76 juneau76 is offline
2010 Ford F-150
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
Works for me. Here's the content:
15:05 01 May 2009 by Phil McKenna
For similar stories, visit the Energy and Fuels and Cars and Motoring Topic Guides
The energy crisis has given rise to a new source of fuel – the Styrofoam cup. Mechanical engineers at Iowa State University in Ames have demonstrated how to boost the power output of biodiesel simply by adding waste plastic to the fuel.
Song-Charng Kong, a co-author of the study, says the experiment – funded in part by the Department of Defense – was conducted to find a way to dispose of trash and generate power under battlefield conditions.
"One can recycle any kind of plastic, but if you are camped in a remote area, recycling is not an option," Kong says. "Turning plastic into fuel is a way to get rid of garbage and generate electricity."
Kong and colleagues dissolved polystyrene – a polymer used to make disposable foam plates and cups – into biodiesel at concentrations ranging from 2 to 20% polystyrene by weight. "A polystyrene cup will dissolve almost instantly in biodiesel, like a snowflake in water," Kong says, although the plastic doesn't break down as well in petroleum-based diesel and other liquid fuels.
Thicker juice
Tests of the mixed fuel in a tractor engine used for electricity generation showed that as polystyrene concentrations increased to 5%, power output increased at roughly the same rate. However, there was a drop off in output for plastic concentrations above 5%.
Kong thinks the change is due to the fuel's increasing viscosity as more and more polystyrene is added. Initially, he says, the thicker fluid creates greater pressure inside the generator's fuel injector causing earlier injection of fuel into the engine and increasing its output.
But eventually the fluid gets so viscous that it doesn't completely combust in the engine and power output decreases. At 15% polystyrene, the fuel is so thick the fuel injection pump overheats.
The new fuel mix is not without its problems, however – as the concentration of polystyrene increases, so do emissions of carbon monoxide, soot, and nitrous oxides.
"You are putting large polymer compounds in, it's hard to burn them completely," Kong says, adding that he hopes to now work on refining the engine's fuel injection system to yield a more complete burn with fewer emissions.
Bulky problem
Robert Malloy of the University of Massachusetts Lowell says as long as emissions can be brought back into line, adding polystyrene into fuel makes sense.
A recent report suggests it's over three times as energy efficient to recycle trash rather than convert it to fuel, but Malloy points out that polystyrene is a special case.
"I think we should try to recycle as much as we can, but there are certain materials that don't lend themselves to recycling in an economic way," he says. Polystyrene is so lightweight and bulky that it's uneconomical to ship to recycling plants. "Technologies like this where you get energy back would be preferable to landfilling," Malloy says.
__________________
Brad
2010 F-150 XLT Supercrew 4x4 5.4L
2013 Explorer Limited (The wife's family truckster)
Quote:
You haven't lived life until you've done 110mph in a Yugo
  #4 (permalink)
Old 06-06-2009, 05:14 PM
Rushmore X's Avatar
2003 Ford Excursion
Give us your styrofoam cups???
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Fordฎ is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
