90 ignition system wiring diagram needed - Ford Truck Enthusiasts Forums
Old 06-05-2009, 09:55 AM
MONAVIERONJON MONAVIERONJON is offline
MONAVIERONJON is starting off with a positive reputation.
Hey FTE's I just thought about how our manufacturer isn't bankrupt andtheres nobody talking about them whatsoever.And that makes me even more proud of my Ford's,how about U? This truck is a 1990 and seems to be a problem in the steering column key switch/ignition that isn't allowing power to the injectors so i am seeking a wireing diagram for the cylinder on through the engine so that i might understand what a fues link is.This manula doesn't tell me where the Yellow wires go to so your help is desired.Thanks!!!!!!!!
1953 Turn Signal Wiring Vin Man 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 09-29-2014 09:27 PM
Changing cap, rotor, wires FordYoungGun35 1987 - 1996 F150 & Larger F-Series Trucks 16 05-20-2013 12:25 PM
Need help with ignition wiring identification Chocko 1973 - 1979 F-100 & Larger F-Series Trucks 6 12-12-2012 07:40 AM
Firewall wiring diagram fixinoldfordtrucks 1973 - 1979 F-100 & Larger F-Series Trucks 9 05-11-2011 06:45 PM
Wiring diagrams mr_s_edwards Aerostar 1 12-30-2000 01:19 PM
Tags
1987, diagram, f350, ignition, system, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
