1990 F150/5.0 oil pan removal - Ford Truck Enthusiasts Forums
Old 06-05-2009, 09:38 AM
House Husband House Husband is offline
House Husband is starting off with a positive reputation.
Is it possible to remove the oil pan without removing the engine?
Thanks
Richard
Old 06-05-2009, 11:39 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
yes. You will need to remove the upper plenum and y pipe. Then unbolt the engine mounts and pick up the engine as far as it will go.
Unbolt the pan and snake your arm in to unbolt the oil pump. Everthing will come out then
Old 06-05-2009, 12:19 PM
Thanks Brad, That was exactly what I was looking for.
Richard
Old 06-05-2009, 12:29 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
it is a little more involved then that.
clearance between crossmember and pan an trans. is "o".
radiator shroud needs to come off.
other tips if you do an advanced search in this forum.
Old 06-05-2009, 08:23 PM
Thanks QL2.
I already suspected the fan shroud. The fan clutch is FUBR, so I'll just remove it and leave the fan in the shroud. That will take care of the fan hitting the shroud.
Thanks
Richard
Old 06-05-2009, 11:45 PM
42x 42x is offline
42x is starting off with a positive reputation.
If you are trying to replace the oil pan gasket you do not need to remove anything. Unbolt the pan then wrestle the gasket in. The oil pump pickup is difficult to get under but it is doable...assuming this is what you want to do.
Old 06-06-2009, 03:12 AM
NashT's Avatar
NashT NashT is offline
NashT is starting off with a positive reputation.
Its actually really easy to take off the pan if you have access to a lift,
don't forget the four bolts on the bottom of the timing cover
Old 06-06-2009, 11:05 PM
The old truck has 100,000 miles on it. When I fire it up, the mains bang until the oil pressure comes up. The the oil pressure will drop to almost zero when hot, at an idle. The ol beater will get less than 2,000 miles a year, hauling limbs and trash. I intend to roll in a new set of mains, rod bearings and a new oil pump. You would be surprised how long a set of bearings last on a less than perfect crankshaft. I've done this before on old engines with success. Thanks for all your responses.
Richard
Old 06-09-2009, 01:07 AM
bonzi88's Avatar
bonzi88 bonzi88 is offline
bonzi88 is starting off with a positive reputation.
Quote:
Richard
Been there , done that a few times too. Helped a brother-in-law do that years ago in his Ford van, 2 of the original rod bearings actually spun on the crank. He put another 60,000 miles in that old van till a king pin froze & tore of the tie rod end.
FE OIL PAN 72CC428 1967 - 1972 F-100 & Larger F-Series Trucks 15 06-05-2016 03:08 PM
Oil pan help wheelieking Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 04-05-2015 08:11 AM
change oil pan gasket Bigal700 1994.5 - 1997 7.3L Power Stroke Diesel 11 05-09-2014 12:49 PM
oil pan removal? erik68 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-04-2014 09:03 PM
2000 F-150 4.6L Oil Pan Removal truedouble 1997 - 2003 F150 0 08-16-2011 09:01 PM
Tags
1990, 1995, 1996, 50, 90, f150, ford, gasket, oil, pan, removal, remove, removing, replacement, van, vans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
