new engine lifter noise - Page 7 - Ford Truck Enthusiasts Forums
  #91
Old 06-13-2009, 07:18 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
If the 'ridge' is the machined ridge that is used by the valve spring retainers, I'd vote for removing the head. And doing a thorough inspection of all valves and the other head.
When you have the rocker arms and shaft off, all the valve stems should be at the same height.
I did have a 302 once that had multiple diameter valve stems on the same head. From the factory. Must have been a 'broken tool' head that was salvaged by oversizing one valve guide. I had to search all over for an oversize stem replacement.
tom
tom
  #92
Old 06-13-2009, 10:22 AM
kettle-one kettle-one is offline
kettle-one is starting off with a positive reputation.
Glad you got it, I went threw the the same issues in my 340, between the guides being too long for my cam lift, bending push rods and whipping out cam lobes, I hope my issues are resolved. If they disassemble your heads and go over them, let them know what cam your running to make sure you have enough spring pressure and clearance. Shops do make mistakes, a well know shop in my area put a guide in crooked on my dad's 352 PI heads, after he broke two rocker shafts, he installed girdles, 15 years later, had the heads redone and found the crooked guide, we still do business with them because they stand behind and still do good work. I'm gonna go see my dad's 410 in his highboy, it should be a screamer! (That's why I need my scj 460 done!) Good Luck and keep us posted!
  #93
Old 08-26-2013, 12:27 AM
Godspeed777's Avatar
Godspeed777 Godspeed777 is offline
Godspeed777 is starting off with a positive reputation.
I know this post was last written to 4 years ago, but just in case someone does what I did and found this post looking for a lifter rattle or lifter tap noise, I wanted to post this. I was freaking out that I had a major engine problem. Had a really good engine builder tell me the noise was from exhaust gas leaking through the guides, or a collapsed lifter. I read some other posts that suggested it may be a fuel pump noise, but I blew off the advise thinking that the noise was too loud and too much like a lifter tap (or even a rod knock) to be a fuel pump noise. Guess what...it was the fuel pump. The noise went away just like a lifter that gets pumped up at higher engine speeds and oil pressure. I was never so happy to be wrong! Fuel pump noise it is!
2008 f250 SD lifter noise strat875 Modular V8 (4.6L, 5.4L) 0 09-20-2016 12:00 AM
Lifter Oldschool2888 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 1 08-01-2016 08:33 AM
roller lifters billyrayf150 Performance & General Engine Building 1 02-13-2016 12:50 PM
lifter troubles normalmike 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 11-07-2013 12:48 AM
Bad lifter or something more serious? nnewman Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 9 07-04-2010 11:13 PM
Tags
1997, 23, 390, engine, fe, ford, lifter, lifters, noise, pin, push, ranger, rod, series, tapping, wrist
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
