1998 Ranger supercab 4x4 4.0L Automatic.
Old 06-05-2009, 08:35 PM
davidstjohn1's Avatar
davidstjohn1
davidstjohn1 is offline
yes it did sound like marbles but its nearly gone now! i still have half a tank to run out this is great. and thanks for the info i will do what u suggested with the techron. :-)
Old 06-06-2009, 09:15 AM
davidstjohn1
its getting even better and it goes away completely for minutes at a time.
Old 06-06-2009, 09:35 PM
davidstjohn1
Ok! I finished the tank full of gas and it has completely gone away no marble sounds or anything. Infact it sounds awsome..... I cant believe it its so quiet cuz i thought for sure i bought a truck with some engine damage :-/ but i was wrong.. Thanks to u guys who helped me thanks a lot...
Old 06-06-2009, 10:49 PM
pawpaw's Avatar
pawpaw
pawpaw is offline
OK, good feedback & to hear your marble noise seems to be gone.
Hard to tell just what was causing it, but seeing as how it wasn't noisy when you checked it out the first time, but was noisy when you picked it up & the owner had just changed the oil & filter, I suspect his oil change sequence caused it.
BUT, seeing as how it has over 100K miles on it, a good decarbon treatment sure won't hurt it!!!!
Go ahead & use the Techron before filling up on this next tank & continue the spirited driving while running most of this next Techron treated tank out.
When you change the oil next, use the change sequence & oil filter pre-fill & engine prime/purge technique I posted & let us know how it goes.
Old 06-06-2009, 11:26 PM
davidstjohn1
ok i will do that to the letter! love this site i can learn a lot here. thank you.
Old 02-23-2010, 06:00 PM
davidstjohn1
I changed the oil and used the technique u explained here and didnt have any marble noise at all... the engine is as quiet as ever smooth as silk... thanks pawpaw
Old 02-23-2010, 07:00 PM
pawpaw's Avatar
pawpaw
pawpaw is offline
OK, good feedback & to hear you didn't have any start up noise after your oil & filter change.
The first time I changed the oil & filter on my then new 99 pushrod 4.0L, I had awful marbling about 30 seconds after the start up, scared me to death & it took about 4 days for it to stop.
I thought I had screwed up my oil change & omitted a couple of qts of oil.
Took a few more changes to work out the filter preill & drain & refill sequence of disabling the fuel pump so the engine wouldn't start, then to crank it over to purge the remaining air out of the oiling system & to bild pressure in the system routine, but it still works for me too & I do it every time after every oil change!!!!
Manofgod4life
03-10-2015 11:40 AM
strokersace
20
01-13-2011 03:07 PM
Jrogosich
08-18-2010 11:56 AM
daggerNC
17
01-13-2006 11:36 AM
Quick Reply: 1998 Ranger supercab 4x4 4.0L Automatic.
