Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #121 (permalink)
Old 10-10-2009, 10:56 AM
BigSix1 BigSix1 is offline
BigSix1 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Diesel_Brad View Post
Thanks BigSix1
The welder is a Miller 210. I love it! I can weld thin sheet metal up to 1/2" plate steel
As for clear coat. It is easier than single stage. you lay down the color first. I as many coast as you need to cover. And it has about a 10 min flash time as opposed to 30 min w enamal. As for the clear.... you just put it on like another coat of paint. Everyone has their own preference on how to do it but i do it in two coats. One light , tack coat . then one heavy second coat to make it smooth.
You're welcome, man! Thanks for posting the thread.
Yeah--the Millermatic 210 looks awesome! I was told that my 150 was built on the same, basic architecture, that was then upgraded to the 175 and then the 210--your pic looks very much like my 150. My 150 could use a little more "oomph," but I'm using it on a 100' extension cord I made (for now--IIRC, it's 10 ga., stranded) and I'm hoping when I make up a shorter cord that will give it a "boost." I'm probably experiencing some voltage drop at 100+ feet.
So...the paint designed for a clear coat you can put down in as many, lighter coats as necessary, to cover? That sounds good to me, as my fear is making RUNS. (I think you left out an "n", above, but I believe I got your meaning).
So, you get the color on good enough, waiting only 10 minutes between (thin) coats, and then just one or two coats of clear? (I like to do a tack coat first, too, then go for the gloss, rather than all-in-one coat, when I spray enamel). It does sound a little less intimidating, when you put it that way.
How "runny" is the clear coat? Any worse than regular paint? Better? Are th runs harder to see in clearcoat than in paint? Can you sand the runs out, as with paint, and then compound it back to shinytown?
Thanks again!
Big Six
__________________
Real trucks have clutch pedals....
1972 F-100, 240-I6 (slushbox ), 2x4, ("restified")
1981 F-100, 300-I6, 4 spd manual with O.D., 2x4 (currently functioning as a shed)
1988 F-150 300-I6, 5 spd. Mazda, 2x4 (FOR SALE)
1997 F-250 H.D.S.C., 460, 5 spd. ZF, 4x4
  #122 (permalink)
Old 10-10-2009, 07:09 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
1980 Ford F-350
My Garage
Diesel_Brad is starting off with a positive reputation.
Thanks again!
Big Six
The clear can be runny, but if you use the thinner for the temp you are spraying you will be fine. It takes practice as to what the finish looks like for correct orange peal or a run.
As for runs, sanding them out can be simple or if you have a major run, you may sand it out so it is no longer felt but it will be like a shadow if it is a heavy run
__________________
myspace.com/diesel_brad
96 F350 460 5pd 4x4 crewcab
94 F150 Lightning
86 F250 6.9 4spd 4x4
80 F350 429 C6 4x4
  #123 (permalink)
Old 10-10-2009, 11:12 PM
Countrywfo's Avatar
Countrywfo Countrywfo is offline
Countrywfo is starting off with a positive reputation.
lookin good man, sharp lookin ride
  #124 (permalink)
Old 10-11-2009, 06:19 PM
FreemansF150 FreemansF150 is offline
FreemansF150 is starting off with a positive reputation.
Diesel_Brad,
I noticed that you were using one of the pot style sandblasters in the page 1 pics. How does it work for you on body panels? I am looking at the 10 gal one at Harbor Freight so that I can blast the frame and bed on my 79.
Any thoughts or suggestions are appreciated.
John
  #125 (permalink)
Old 10-11-2009, 06:44 PM
1980 Ford F-350
My Garage
I replaced it w one of these Pressure Blaster Model 110 from EASTWOOD. I didn't pay that price. I w am lucky enough to live an hour from them and they had a scratch/dent special i got for $100. And for any large jobs you need BIG compressor. I have a DEVIBLIS 7hp 80gal tank that could not keep up w the little sand blaster. I now have a 4 cyl gas powered tow behind compressor to do my sand blasting. For small jobs or spot blasting a pot blaster and an electric compressor is fine, but if you want to do a frame, complete truck or a large job. Go get a tow behind and at least 100lb pot
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #126 (permalink)
Old 10-11-2009, 07:42 PM
benmoderow benmoderow is offline
benmoderow is starting off with a positive reputation.
Hey brad, I'm also curious to know how you stripped your body panels? Everyone says you can't sand blast them because they will warp, but I would really like to do it myself to save some $$. Trucks lookin sweet!
  #127 (permalink)
Old 10-11-2009, 07:54 PM
1980 Ford F-350
My Garage
I stripped the panels by sanding because i did not have the bigger pot and compressor. It took forever. I stripped the bed by sand blasting, but i used only 60psi and hit it at a 45*. No warped panels or anything. It is when someone uses 120 psi and hits it a 90*
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #128 (permalink)
Old 10-11-2009, 08:04 PM
muladesigns1's Avatar
muladesigns1 muladesigns1 is offline
muladesigns1 is starting off with a positive reputation.
great progress! very good quality work as well (thats getting harder to come by nowadays)
If you ever find your way in Az look me up and you got a job at my shop!
  #129 (permalink)
Old 10-11-2009, 08:22 PM
1980 Ford F-350
My Garage
Thanks! that means a lot. There are a bunch of morons over on the 87-96 forum talking about a $50 paint job. I gave them hell , and said that is just a hack way to do things and they say i have too much time and money to do things the way i do. I just say " do it right or not at all"
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #130 (permalink)
Old 10-11-2009, 08:25 PM
I could'nt agree more! theres nothing worst then seing someone hacking up and spray bomb painting an otherwise really cool vehicle. especially when these trucks are rising in value.
Tags
1979 , bumpside , f150 , pa , sale , stepside
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
