Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 07-05-2009, 08:07 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
1980 Ford F-350
My Garage
Diesel_Brad is starting off with a positive reputation.
Doors cut in. they turned out awesome
Photobucket
Photobucket
Photobucket
__________________
myspace.com/diesel_brad
96 F350 460 5pd 4x4 crewcab
94 F150 Lightning
86 F250 6.9 4spd 4x4
80 F350 429 C6 4x4
  #32 (permalink)
Old 07-05-2009, 09:25 PM
wyazel1's Avatar
wyazel1 wyazel1 is offline
wyazel1 is new and has a neutral reputation at this point.
The 1 ton crew cab in the background is lookin good also. Good work.
__________________
76 150 4x2 390 4v
78 F150 4x4 408cid
95 F250 SuperCab 4x4 460 Auto
  #33 (permalink)
Old 07-07-2009, 08:52 PM
1980 Ford F-350
My Garage
Got a lil energy today, Stripped the cab and and pulled the inner fenders , nose and cab
PhotobucketPhotobucketPhotobucketPhotobucketPhotobucketPhotobucket
Photobucket
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #34 (permalink)
Old 07-07-2009, 10:23 PM
shadowviper12345 shadowviper12345 is offline
shadowviper12345 is new and has a neutral reputation at this point.
why did you crush the cab?
  #35 (permalink)
Old 07-07-2009, 10:36 PM
shameless's Avatar
shameless shameless is offline
shameless is starting off with a positive reputation.
probably an accedental slip of the hydrolic controlls. those tractors controlls can be touchy sometimes.
__________________
79' F150, 4x4, longbed, 351m, auto
"Negligence, is failing to act properly when you have a duty to act."
  #36 (permalink)
Old 07-07-2009, 11:22 PM
1980 Ford F-350
My Garage
Trust me. That is the least of the cabs concerns. Once i pulled the carpet up, the hole for the windshield looked small. LOL
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #37 (permalink)
Old 07-07-2009, 11:31 PM
liftnw8z's Avatar
liftnw8z liftnw8z is offline
1997 Ford Explorer
liftnw8z has a good reputation on FTE. liftnw8z has a good reputation on FTE.
That's a PA cab for you. Rust is such a huge problem on anything...I have to get 2 doglegs cut in and welded on my Explorer because of it.
Looking good, Brad. Should come together really well when it's all done.
__________________
Bill Boomer Sooner!
97 Explorer 4 dr - 4.0L V6 - Auto - ControlTrac 4x4 - Flowmaster Force II - Bilstein Shocks
Pennsylvania FTE Chapter Member
See here for info on the 2010 MidAtlantic Meet at ATN's
Still dreaming about money...and waiting for the project$ to $pend it on...
  #38 (permalink)
Old 07-07-2009, 11:40 PM
1980 Ford F-350
My Garage
Yeah. i was going to take some photos for the west coast guys who think they know what rust is
Just look at some of the first few pics on the 1st page. You can see the roof rot
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #39 (permalink)
Old 07-08-2009, 12:08 AM
76f350spercamprspeal's Avatar
76f350spercamprspeal 76f350spercamprspeal is offline
1976 Ford F-350
My Garage
76f350spercamprspeal has a very good reputation on FTE. 76f350spercamprspeal has a very good reputation on FTE. 76f350spercamprspeal has a very good reputation on FTE.
Yeah,I think my truck is rusty.
I seen some of the other trucks online (Which are way worse than yours)
__________________
-With all Due Respect-
--Anthony-- -*~<-76SCS->~*-
*Anthony's Truck Pictures *Anthony's Truck Pictures-2 *Anthony's Truck Pictures-3
Father's Formally owned-67 F250-69 F250-77 F350-93 E350-*--Join The SoCal Chapter *Here*
  #40 (permalink)
Old 07-08-2009, 12:34 PM
1980 Ford F-350
My Garage
cab perch rot
Photobucket
Photobucket
Photobucket
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #41 (permalink)
Old 07-08-2009, 01:58 PM
Recoil's Avatar
Recoil Recoil is online now
Recoil is starting off with a positive reputation.
Quote:
Originally Posted by Diesel_Brad View Post
Prob like 20-25lbs
That sounds about right, I just had my doors off and stripped to the metal. They were about the same weight.
The truck is looking great!
On a side note. Do you have any pictures and specifics on how you repaired the hole in the top of the cab that the CB antenna went through? I have the same hole to repair.
Thanks.
__________________
~Will
MOΛΩN ΛABÉ
1976 F-150 4x4 390
  #42 (permalink)
Old 07-08-2009, 02:23 PM
1980 Ford F-350
My Garage
The hole was approx 1" diameter. I took a 3" square piece of sheet metal, then covered the whole piece w panel adhesive. stuck it in place on the inside, wedged it tight into place using some paint sticks between it and the support in the roof. I let it sit for 24 hours . The panel adhesive not only glued the patch to the inside of the roof, it also "filled" the hole itsself. I just sanded the glue down from the out side and a skim coat of finishing glaze. No heat from welding to warp the roof and nowhere to start rust.
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #43 (permalink)
Old 07-08-2009, 02:29 PM
1980 Ford F-350
My Garage
Photobucket
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #44 (permalink)
Old 07-08-2009, 05:09 PM
Recoil's Avatar
The hole was...nowhere to start rust.
Cool, thanks!
Great job on the cab mounts!
__________________
~Will
MOΛΩN ΛABÉ
1976 F-150 4x4 390
  #45 (permalink)
Old 07-09-2009, 04:27 PM
1980 Ford F-350
My Garage
The frame was power washed, grinded down, powerwashed again, rolled in the garage, wheels off, cleaned the drums and front brake hardware, Then whiped down and sprayed. Took almost a gallon!
Photobucket
Photobucket
__________________
94 F150 Lightning
80 F350 429 C6 4x4
Tags
1979 , bumpside , f150 , pa , sale , stepside
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
