2002 7.3L Turbo Flutter
It is called surge, 7.3's will get it when chipped. You can hear it because of
the Tymar. With the stock filter you wont hear it, but it will still do it and destroy
the turbo after awhile. There are 2 solutions...
1 - This will cure it.. ATS ported housing (I did this) $350 or so
2 - Usually cures it... Wicked Wheel - but creates more turbo noise $75 or so
Also, get custom chip by Total Diesel Performance or DP.. So much better
than that super chip...
Check with Clay (Riffraff Performance) to get a good deal on either the ported shroud housing, a wicked wheel, or a 1.0 A/R exhaust housing.
Definitely check with Clay, the man does good business and knows how to take care of his customers.
Thanks for clearing that up Chase.
If you exceed 22PSI of boost on a 7.3L you will need a boost fooler to prevent a high boost code. There are a few other ways to get more boost, a $5 bleed tube and $5 boost fooler or an adjustable wastegate that unlike the bleed tube will prevent wastegate creep, assuming you have the power to generate the turbo drive pressure. I am not just here to make a profit guys, I am here to assist first and sell second. heck... if you like the bleed tube and boost fooler are so inexpensive I will send them to you no charge if you like, just pay this shipping and read my catalog.
That's what it was, because I thought about it long after I posted: people unplug their wastegates all the time and nothing bad happens.......until you over do it."
Dave (BD Power)- what is this $5 boost fooler you speak of? I know what the bleed tube is, but what about the fooler?
