1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
broken exhaust studs
Old 06-04-2009, 11:01 AM
joeycyph56's Avatar
joeycyph56
joeycyph56 is offline
Hi i i have an 06 f250 sc 5.4l with 20,000 miles. i noticed recently while towing my boat that there was a ticking noise coming from the front of the truck.As i drove on with a load on the truck the noise becomes louder and now over a 3 month period is getting worse.Since i have a few weeks left under my 3/36k warranty i brought it in to the dealer to learn that the exhaust manifold bolts on the passenger side are broken and the manifold is leaking .When i asked the dealer if they have a fix,such as stainless studs, he said no they just replace with what ford gives them and that the problem will return eventually. My question is I thought they resolved this issue on the newer models,after 04. I asked if i got stainless studs if they would install and he said yes.Does any one know where i can get stainless exhaust manifold studs, And would this help stop the rotting problem of the stock studs or are they not worth the money. Thanks
Old 06-04-2009, 11:12 AM
Bear River's Avatar
Bear River
Bear River is offline
Former ******
They are right, use the ones Ford give you. The problem with the stainless studs is galvanic welding. Plus stainless is not entirely corrosion proof, especially at those temperatures. When you use the stainless studs, they permanently weld together, making them almost impossible to remove. And you can't cut them with a standard torch.
I would say its not worth the money to get stainless studs. If you do, be very specific about the type of stainless. Make certain it is marine grade stainless, anything else will still rot, it just takes longer than standard steel.
Old 06-04-2009, 11:45 AM
WestxSRT10's Avatar
WestxSRT10
WestxSRT10 is offline
I wouldnt use stainless bolts! If i ever have a problem with mine i'm going to use Grade 8 ARB bolts with a tiny bit of anti-seize.
Old 06-05-2009, 11:19 AM
joeycyph56's Avatar
joeycyph56
well that answers the stainless question but what about the issue that it happened on a truck that has been in service for not even 3 years?..I understand that the low miles mean that it sits more than it is driven but it has stayed sheltered till recently.Its just a shame y yet oh well thanks
Old 06-05-2009, 11:46 AM
WestxSRT10's Avatar
WestxSRT10
I think the bolts fail because of their poor quality not external rust. They become brittle from the heat/ cool cycling and break.
note... I stand corrected: (there are some grades of stainless steel bolts than can be used on exhaust manifolds)
Old 06-06-2009, 09:19 AM
bobh's Avatar
bobh
bobh is offline
exhaust studs
I had mine replaced by Ford dealer. The new studs are stainless steel
coater with copper I beleive they said. The nuts are copper or brass.
Old 06-11-2009, 10:39 AM
joeycyph56's Avatar
joeycyph56
well i just got my truck back from the dealer and its nice and quiet now.They told me that that the exhaust manifold gasket had warped and wasnt sealed, so they replaced the passenger side gasket plus the bolts and a couple other parts listed on the invioce.I dont get how a gasket warps thats bolted between two parts but shes fixed i guess and im happy.What also gets me is that i was told this was a comon problem on the passenger side but yet i dont believe i heard anyone else have this problem.
Old 06-11-2009, 11:18 AM
cparks's Avatar
cparks
cparks is offline
Maybe the manifold was warped, and they replaced that. Not sure, but does Ford even use a exhaust manifold gasket from the factory? I know the older ones did not have a gasket.
Old 06-12-2009, 11:51 AM
ironmine's Avatar
ironmine
ironmine is offline
Thats what happened with my '02 ..... some studs failed and the manifold warped. I *believe* the studs I got from Ford with the manifold were stainless with some sort of unreactive outer coating/treating.
Old 06-12-2009, 12:47 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
The stock studs are stainless.
They either fail at the shoulder (bad heat treatment) or down in the threads.
The problem is related to the manifold expanding and contracting, and the original nuts rot and stick to the manifold. The manifold expands and contracts, it drags the nut with it, and eventually fatigue the stud.
My '01 V10 had sheet-metal gaskets.
I think the copper plating on the nuts is to try to keep them moving in relation to the manifold, but that's just a theory.
Old 06-12-2009, 09:15 PM
Pinky Demon's Avatar
Pinky Demon
Pinky Demon is offline
Got this problem myself at 67k mi. I'm going to do a complete swap with a Banks system soon.
motorfixer1
2009 - 2014 F150
16
09-23-2015 10:48 AM
oxbronco
Modular V10 (6.8l)
11-29-2013 09:50 AM
lizzie73
Modular V10 (6.8l)
07-06-2011 02:32 PM
02mudbug
17
02-20-2006 01:50 PM
hink10
1997-2006 Expedition & Navigator
13
07-04-2004 01:52 AM
Quick Reply: broken exhaust studs
