Front drive shaft 78 F150 4x4
I'd like to place a WANTED ad in the classifieds on this site for a front drive shaft, but I'm not sure what info will be required.
I have a 78 F150 460 4x4. All I know about the t-case is that it's mated and I'm not even sure which front end I have.
I do know that the brake line/hose assembly I got has the metal line and rubber hose all as one piece and it's pre-bent. Since the one I got was out of the book and it fits, I assume that the front axle is the original one.
The front drive shaft (2 piece) is loose at the joint, and it will cost $200 for a machine shop to put on a new tip.
Did Ford make different length/type front shafts for my truck?
What another years had the same shaft?
As always, any help would be greatly appreciated!
Thanks in advance!
Kevin K.
Thanks in advance!
Kevin K.
KJKozak2
05-13-2005 04:41 PM
KJKozak2
01-16-2003 08:58 PM
