Turbo bolt pattern?
Turbo bolt pattern?
Hey fellas, I got a brilliant idea while I was reading through the psd custom turbo thread.
Seeing as I have an extra Banks turbo pedestal on hand...what other turbochargers would fit that rectangular bolt pattern on the pedestal? If I can get that figured out, along with my own piping and oil system, I just might fab up my own turbo system.
Anyone have an idea? I might be able to get some dimensions if it will help. Thanks.
-Dave
-Dave
-Dave
-Dave
post a pic of it, the thing i hate about the psd turbo is that it has oil pressure and return in the same side which makes thing hard, but psd turbos are plentyful and farliy cheap to upgrade and rebuild
that turbo mount flange is a t3 flange hypermax is a t4 flange (wont work). there are many turbos that will mount even internal wastegated turbos... just need to make sure waste gate clears everything on the engine.
before you pick a different turbo you need to make sure it is sized correctly for your engine ie. cfm and pressure ratio... some will choke the engine and others will launch the heads into the hood.
go to garretts website they have a good writeup on sizing turbos.
I will have to go and read the literature on the Garrett website. Thanks for the tip.
-Dave
