1993 lightning with 2001 lightning rims please help...
ok guy have had these 01 rims for awhile now but i recently bought a 93 lightning and i had wheel adaptors on my old 81 to make them fit but i read on a post on this site that to make them fit without the adaptors just grind a lil off the rims well i did that and now i cant find a lug nut to fit just right? i have the stock 01 lug nuts but the studs are not big enought what do i do change the studs to a 01 or do they make those lug nuts in differnet sizes with the washer thanks for the help trevor
The F150 used 1/2-20 studs forever until 97. Then used 12mm studs from 97-00 and 14mm studs from 01 up with the usual transition time that could go either way. 97-up wheels don't fit the earlier trucks. The later trucks use a hubcentric wheel and the early models used lugcentric. I have heard it said that all are hubcentric but the early trucks are also lugcentric, but don't know if that's true or not. Why not just use your adaptors and be done with it?
#1 08-31-2007, 11:44 AM
lowered96
New User Join Date: Apr 2005
99/00 Lightning wheels on a 96
Im looking to put a set of 99/00 lightning wheels on my 96. Will the factory lightning wheels be a direct bolt on, or do I have to find replica wheels with the correct bolt pattern?
__________________
lowered96
View Public Profile
View Gallery
Send a private message to lowered96
Find all posts by lowered96
Add lowered96 to Your Buddy List
#2 08-31-2007, 11:45 AM
ss150
Senior User Join Date: Jul 2007
I have been told that they have the same bolt pattern, so it should be no problem.
__________________
ss150
View Public Profile
View Gallery
Send a private message to ss150
Send email to ss150
Find all posts by ss150
Add ss150 to Your Buddy List
#3 08-31-2007, 12:26 PM
EPNCSU2006
Post Fiend Join Date: Nov 2002
That is not correct. The 97-up F150's used a 5 on 135mm pattern, while the 96-older used a 5 on 5.5" pattern, so the 99/00 lightning wheels will not be a direct swap. A set of replicas with the correct bolt pattern are in order.
__________________
Eric
'87 F150 302 manual 4sp overdrive 4x2
EPNCSU2006
View Public Profile
View Gallery
Send a private message to EPNCSU2006
Send email to EPNCSU2006
Find all posts by EPNCSU2006
Add EPNCSU2006 to Your Buddy List
#4 08-31-2007, 02:40 PM
ss150
Hmm, thats funny. Someone on here a while back told me you could use the same wheels. Do the first gen Lightnings have the same bolt pattern as the second gen? I have seen them on older Lightnings a lot, and I remember someone on here with a Lightning telling me that they work. Idk now...
__________________
ss150
View Public Profile
View Gallery
Send email to ss150
#5 08-31-2007, 05:12 PM
Blurry94
Rate This Moderator: 12345678910 * 1 - Low and 10 - High
Your comment:
There are a few GEN 1 L owners that had the factory 99+ lightning wheels modified. I believe they just opened the holes up a bit and got the 99+ style lug nuts.
There are a few companies that make replicas and for the older wheel bolt spacing; 5x5.5".
__________________
Matt C.
94 Lightning, blown/intercooled stock longblock, 1.76 60' 7.94 @ 90mph (1/8 mile)
01 F-150 4.6 2wd RC, K&N drop in, shorty headers, Flowmaster w/duals
Blurry94
View Public Profile
View Gallery
Send a private message to Blurry94
Find all posts by Blurry94
Add Blurry94 to Your Buddy List
#6 09-01-2007, 11:09 AM
ss150
Oh ok, thanks blurry. What's the cheapest place you guys found the replicas with 5x5.5"?
__________________
'92 F-150 Flareside 302 E40D 3.55's
MSD cap & rotor, Flowmaster muffler
ss150
View Public Profile
View Gallery
Send email to ss150
#7 09-05-2007, 04:47 PM
lowered96
Yeah, where can I find a set of Replicas. I want to put these wheels on my 96.
__________________
lowered96
View Public Profile
View Gallery
#8 09-05-2007, 05:06 PM
wd13
Junior User Join Date: Sep 2007
Dont waste the money on the replicas. You can usually find the factory Gen 2 L wheels for 300-400 bucks. All you need to do is open the holes up a bit so the 5x5.5 pattern fits. Its been done a million times and is much cheaper.
__________________
wd13
View Public Profile
View Gallery
Send a private message to wd13
Find all posts by wd13
Add wd13 to Your Buddy List
#9 09-05-2007, 11:32 PM
ss150
That's actually what I prefer to do, since I have better access to OEM's. How much do you have to widen them, and how do you adjust for the larger holes?
__________________
ss150
View Public Profile
View Gallery
Send email to ss150
#10 09-06-2007, 08:33 PM
wd13
Quote:
You dont have to open them up much at all, not enough to worry about the hole being too large. I forgot to mention , you'll need a factory style lug nut. Ford can fix you up with those reasonably
__________________
wd13
View Public Profile
View Gallery
#11 09-06-2007, 10:56 PM
ss150
You use the 99+ Lightning lug nuts? If that's the case, that's no biggie. My dad has an '01 Lightning, and my brother has an '03 Lightning, so I'm going to try and buy theirs from them and they can get some new wheels or something.
__________________
lowered96
__________________
lowered96
View Public Profile
View Gallery
ss150
__________________
ss150
View Public Profile
View Gallery
Send email to ss150
EPNCSU2006
__________________
Eric
EPNCSU2006
View Public Profile
View Gallery
ss150
__________________
ss150
View Public Profile
View Gallery
Send email to ss150
Blurry94
Your comment:
__________________
Matt C.
Blurry94
View Public Profile
View Gallery
ss150
__________________
ss150
View Public Profile
View Gallery
Send email to ss150
lowered96
__________________
lowered96
View Public Profile
View Gallery
wd13
__________________
wd13
View Public Profile
View Gallery
ss150
__________________
ss150
View Public Profile
View Gallery
Send email to ss150
wd13
__________________
wd13
View Public Profile
View Gallery
ss150
__________________
You'll havr to widen the holes by about 1/8". I don't know where you'll get a lug nut that fits and works properly. You would need a 1/2-20 nut with a shank and washer like the 97-present F-150 uses. Tapered nuts typically don't stay tight hubcentric wheels and the washered nuts may not clear the wheel if you move them out 1/8". Many aftermarket wheel companies make shanked nuts for their wheels that might work. I know Cragar has them for their SS wheels that have slotted stud openings.
I was wondering the same thing. Here is my take...
147mm (135 + 2*stud radius) equates to 5.79 inches, stock is 6 (5.5+2*stud radius so the difference in outside bolt circle is .21 inches. One half of that is .1.05 inches (the radius difference) which is the amount the hole has to move to the outside to make the wheel fit over the stock studs.
If you rebore the lug holes 1/8 inch larger (.125 inches half of which is .0625) that will not be enough change to make it work. If you slot the hole 1/8 to the outside (like an old uni-lug pattern) it should work.
If you rebore the lug holes 3/16 inch larger (.1875) you might just make it but the hole is starting to get pretty large for the stud now.
1/4 inch increase in bore will do it (.125 radius change), but now the stud hole is really large. I would see if a machine shop could slot the holes first...it would make the best fit.
Good luck...would love to see it done.
Kenny
Kenny
well finally finished my 01 lightning rims install they look awesome no more wheel adaptors just took a lil grinding and the right lug nuts cant go wrong much better than those ugly 1 gen wheels not a big fan at all. thanks for the help guys ill post pics when it warms up now all i need to do its lower it a little thanks again trevor
