e4OD/4R100 Cooler Bypass? - Ford Truck Enthusiasts Forums
Old 06-03-2009, 09:39 AM
aaron ford's Avatar
aaron ford aaron ford is offline
aaron ford is starting off with a positive reputation.
Tru Cool states that the 1994-1996 E4OD does not have a cooler bypass, but a 1999-2004 does. How about the 97? Mine is an OBS constructed in November 1997 (which is in the 98 model year?). How can I tell which tranny it has and whether or not it has a bypass? Thanks in Adavance,
Aaron
Old 06-03-2009, 11:58 AM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.
E4od's do not have the by-pass valve. It started on the 99 model that has the 4r100 IIRC
Here's a picture
http://www.dieselsite.com/index.asp?...ROD&ProdID=172
FWIW, I bought the Tru-Cool 4739 MAX from that site w/ the thermal by-pass and like it alot.
http://www.dieselsite.com/index.asp?...ROD&ProdID=205
Old 06-03-2009, 12:02 PM
MADVAN's Avatar
MADVAN MADVAN is offline
MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.
Quote:
Here's a picture
Jim
It was model dependant back in 97.
Some E4's came with the valve. (E-Series)
The E4's with valve have 3/8 cooling lines.
Bill
Old 06-03-2009, 05:48 PM
Cuda_jim's Avatar
Shoot.... learn sumthin new everyday. Thanks for the clarification Bill.
Old 06-10-2009, 03:46 AM
txevt txevt is offline
txevt is starting off with a positive reputation.
nope, the E4OD does not have a cooler bypass. the 4R100 does have one
4-speed bellhousing samickguy15 Clutch, Transmission, Differential, Axle & Transfer Case 9 04-09-2015 01:32 AM
tranny cooler line question 427 fordman Clutch, Transmission, Differential, Axle & Transfer Case 2 12-30-2009 12:32 PM
Transmission Cooler Bypass E4OD linckeil 1987 - 1996 F150 & Larger F-Series Trucks 2 09-12-2009 11:02 PM
E4OD Upgrades linckeil 1987 - 1996 F150 & Larger F-Series Trucks 6 09-06-2009 11:07 AM
97 E40D transmission cooler bypass audimaster 1994.5 - 1997 7.3L Power Stroke Diesel 4 06-05-2007 09:33 AM
Tags
4r100, bypass
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
