1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
lets hear it from the brain trust on carbs
Old 06-02-2009, 07:36 PM
unibody madness's Avatar
unibody madness
unibody madness is offline
my sons 223 single barrel carb appears to be sucking up floats (it's on its third)
i repaired the first one several times before i replaced it, that one lasted a month and now the second one is full of holes. before the latest replacement also goes,is it possible for there to be something going on that is causing the brass to fail, or is it old age and coincidence.
does anyone out there know of a place to buy these???
does anyone out there have some old holly one bbls that would be willing to raid them for parts???
all i read are you fellas replacing the old sixes with all that horsepower..what do you do with your carbs???
all advice and knowledge would be appreciated
john
Old 06-02-2009, 09:02 PM
flipklos's Avatar
flipklos
flipklos is offline
Are they rotting holes, imploding, or exploding. The holley should have a vent for the fuel bowl. If that is cloged it could create a vaccum or overpressure in the float bowl.
I belive that your carb is a Holley #1941. Try the carburator shop. Just type it into google. I have bounced odball questions off him and he seems helpful. If not try a carter YFA off a 240 or 300 six ford. They only stoped using them 20 years ago so parts are fairly easy to find.
Old 06-03-2009, 03:03 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
[SIZE=2]does anyone out there know of a place to buy these???
How many would you like?
This is a 1961 F100, correct?
The original carburetor is a Holley 1V.
C2AZ9550A .. Carburetor Float (Motorcraft CM389) / Obsolete
GREEN SALES COMPANY in Cincinnati OH has 18 = 800-543-4959.
MILLER OBSOLETE PARTS in Binghamton NY has 12 = 800-546-7278.
PARTS INTERNATIONAL in Farmers Branch TX has 9 = 888-727-0418.
KINSEL L/M in Beaumont TX has 8 = 800-816-2894.
CA = Here's are a couple of places to try.
They prolly won't have it listed under the Ford part number.
ENGLER BROS. AUTO PARTS in Santa Monica.
NORTH HOLLYWOOD CARBURETOR & IGNITION.
Old 06-03-2009, 01:59 PM
unibody madness
thanks for all your help.. quick question..my ford shop manual shows exploded views for the 1v,2v, and 4v carburetors on the 61 and they appear to use the same float, are they?
thanks john
Old 06-03-2009, 04:05 PM
NumberDummy
my ford shop manual shows exploded views for the 1V, 2V, and 4V carburetors on the 61 and they appear to use the same float, are they?
The Holley 2V and 4V carbs use the same float (C1AE9550C). The 2V uses one, the 4V uses two.
The 1V carb uses a different float (C2AZ9550A).
The Holley 4V was not offered on V8 (292) pickups (F100/350).
It only available in F500 and larger trucks.
Tigger!
12-17-2011 11:34 PM
crashtke
04-20-2011 06:46 PM
agferna
1997-2006 Expedition & Navigator
01-09-2008 05:36 PM
banginona40
09-09-2007 04:24 PM
Quick Reply: lets hear it from the brain trust on carbs
