Engine shake a little when Idling
Old 06-02-2009, 06:39 PM
2001supercrewf150's Avatar
2001supercrewf150
2001supercrewf150 is offline
Hello, this is my first time on here. I have recently purchased a 2001 f150 supercrew 5.4L . (About month ago) Well to make a long story short... I drove for a week It was fine, but the I went to pull out one day and It started missing very badly. Then the miss went away. No trouble codes or nothing. I had new plugs put in, but the truck still shakes (like a slight miss) when at an idle (550 to 1500 RPMs) Everyone else thinks I'm crazy. I had water in #7 boot unber the coil. That put the light on... fixed that hoping it was the cause of my underlying complaint (poor idle). Not at all... This idle thing started after the first time I had a miss, and has been getting worse. I have checked for vacuum leakes cleaned the MAF and checked the coils. Also a new fuel filter. I even changed where I purchase gas. This is an extremely clean truck... (No rust, stickers still on the frame and axles) and I live in the salt belt in PA.
Please, anymore advice is appreciated... Thanks!
Old 06-03-2009, 11:06 AM
2000Ford2000's Avatar
2000Ford2000
2000Ford2000 is offline
If it's ONLY happening at idle, I'd guess the idle air controller (IAC). Usually when they stick it can or almost dies when sitting at idle, shaking and shuddering as it tries to stay running.
Old 06-05-2009, 08:06 AM
Fishin76's Avatar
Fishin76
Fishin76 is offline
I found out (by accident) that a O2 sensor not reading correctly can affect Idle quality. I had a Secondary O2 sensor on my 04 go bad, I didn't change it for 20k miles, Truck ran fine, but the idle was rough. Thought about trading the truck, dealer wanted the SES light off, I said I'd change it, knew what the problem was. Well, long story shorter, did change the o2, did not trade my beloved truck. and now, my Idle is smooth as silk.
Just my $.02
Old 03-18-2010, 10:38 AM
RGrimes's Avatar
RGrimes
RGrimes is offline
I'm having a problem with idle also. Idles fine in park @ about 1k rpm but when in gear (brake on) drops to about 500rpm and sometimes stalls when makeing a slow turn. 245k miles 4.6l and replaced the IAC at about 145k miles with a autozone one. IAC again?
Old 03-25-2010, 04:23 PM
mwsF250's Avatar
mwsF250
mwsF250 is offline
Advice for both: Try removing the IAC (back of the intake) and giving it a good cleaning with Carb Cleaner.
These do tend to get a build up over time. Cleaning is much cheaper than replacing!
scsmartt
1997 - 2003 F150
13
02-22-2015 09:15 AM
canuckkb
1997-2006 Expedition & Navigator
12-19-2014 04:38 PM
Rusty_S
10-12-2014 11:09 PM
Swagtastic
05-19-2012 02:30 PM
Wilsontc81
1997 - 2003 F150
19
10-12-2011 07:09 AM
Quick Reply: Engine shake a little when Idling
