How do I wire the coil?
wow, that is odd.
I'd start with checking all your grounds, making sure you got them and they have good connections. Approx 90% of all elelctrical problems are due to bad grounds and they can cause all sorts of weird things to happen.
You need a good ground from the battery to the frame, from the engine to the frame, and from the body to the frame. Looks can be decieving, take them loose and wire brush all the rust, scale, and paint from them and try again.
Good luck
Bobby
Good luck
Bobby
Delp73
11-05-2016 07:43 AM
treverd
09-21-2016 09:13 PM
Cougar54
09-20-2015 09:30 PM
